Gauge Cluster - TCCoA Forums
post #1 of 11 (permalink) Old 11-30-2003, 06:38 PM Thread Starter
Gauge Cluster
will a super coupe gauge cluster fit a 3.8 and work properly, im tired of the stupid 85 mph one.
http://cgi.ebay.com/ebaymotors/ws/eB...category=40017
that's the one i like, something in that style
92ILTBird is offline
post #2 of 11 (permalink) Old 12-01-2003, 06:17 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
the SC cluster has a boost gauge, you dont have a blower so the boost gauge wont work. that ebay cluster will work i think.
i happen to have a spare cluster like the ebay one, but i doesnt have a fuel/volt gauge assembly and the odometer numbers dont rotate. i will sell it for $30 shipped, and i will put in a working speedometer with rotating numbers and a fuel/volt gauge assembly. let me know if your interested.
2014 GT
1990 300ZX TT
big mike is offline
post #3 of 11 (permalink) Old 12-01-2003, 06:20 PM Thread Starter
2 things...
1, how hard would it be to install one, if too hard, how much to get it done by pros
2, cash or check and what location
post #4 of 11 (permalink) Old 12-01-2003, 06:26 PM
Motorboatin' SOB
big mike's Avatar
Originally posted by 92ILTBird
2 things...
1 - ill find out for ya
2 - ill accept either, im in TX
2014 GT
1990 300ZX TT
big mike is offline
post #5 of 11 (permalink) Old 12-01-2003, 06:39 PM
13's or Mildly Broken
Swapping clusters is easy. Remove the headlight knob and gauge trim (black piece) Then just remove the 4 bolts holding the cluster in. Once they are out, pull a bit until you can get your hand back there to unplug them, then it's out.
-Andy "Melon"
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
post #6 of 11 (permalink) Old 12-01-2003, 06:45 PM Thread Starter
hey, thanks alot
\m/
post #7 of 11 (permalink) Old 12-01-2003, 06:53 PM
Motorboatin' SOB
big mike's Avatar
-Andy "Melon"
dont you have to change wiring harnesses?
2014 GT
1990 300ZX TT
big mike is offline
post #8 of 11 (permalink) Old 12-01-2003, 06:58 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
I think the wiring harnesses are the same. Ford used the same wiring harnesses for pretty much everything. I think it includes the gauge cluster.
-Thomas
Thomas is offline
post #9 of 11 (permalink) Old 12-01-2003, 07:04 PM
Harness connector itself - no. It clips in. But wiring behind it, probably. I'm not 100% sure about changing the wiring for speedometer, fuel gauge, and temp gauge. But you will probably have to for oil pressure and volts gauge and run a wire for the tach. I'd get the other cluster, put it in, and go for a quick spin around the block to see what works and what doesn't. Then you'll have an idea where to start.
-Andy "Melon"
Also, not to steal a sale from Big Mike, but I have a full cluster as well for sale.. $30 shipped if his falls through Mike gets first dibs on selling since he offered his first.
2000 Explorer 5.0
Melon is offline
post #10 of 11 (permalink) Old 12-01-2003, 07:07 PM Thread Starter
thats cool, if he cant fix his ill email or pm ya
post #11 of 11 (permalink) Old 12-27-2003, 07:32 PM
I just put a 1993 TBird LX(Sport) instrument cluster in my 1991 TBird with an original three gauge unit. You will need to change 31 of the 32 wires and add a few gounds, a few positive wires, and you will need to run a wire to the ignition coil under the hood for the tachometer signal.
An SC cluster will work just as well as the LX cluster, but you will have a boost gauge for no reason.
You can find wiring diagrams at:
http://forums.tccoa.com/showthread.p...ght=gauge+swap
Speed_Demon is offline
