Air bubble in cooling system - TCCoA Forums
post #1 of 4 (permalink) Old 12-07-2003, 11:24 AM Thread Starter
I think i have a air bubble in my cooling system how would i go about bleeding it out?
--Dan
ArcadiA is offline
post #2 of 4 (permalink) Old 12-07-2003, 11:28 AM
use the little vent plug, on the front of the intake and sticks up by where the radiator hose comes off the intake. Make sure its filled to the top of that vent tube then put the plug back in.
rancherlee is offline
post #3 of 4 (permalink) Old 12-07-2003, 07:58 PM Thread Starter
Ok thanks , because i was told i'd have to remove the upper heater hose and "burp" it, this sounds a little easier
--Dan
ArcadiA is offline
post #4 of 4 (permalink) Old 12-07-2003, 10:23 PM
TCCoA Founder
Sir William's Avatar
If you still have a problem, simply insert a flushing adapter into the highest point on the heater hose. Then once the car is warmed and coolant is flowing, simply gently loosen the cap on the flushing adapter until there are no bubbles. That and the vent will assure that all the bubbles are out.
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
