key wont turn - TCCoA Forums
post #1 of 7 (permalink) Old 12-13-2003, 05:57 PM Thread Starter
key wont turn
went out to start the car tonite and the key wouldnt turn, its kinda like when the steering wheel is locked, but it wasnt locked and i wiggled the steerin wheel and stuff, still no luck, someone plz help me quick, and if u need more info lemme know what u need to know thanks
n3v3tz is offline
post #2 of 7 (permalink) Old 12-13-2003, 06:10 PM Thread Starter
ok, i messed around a lil more and finally got the key to turn but i had to push the brake i never had this problem before, now that i did that it will start fine even without the brake but a few times i had to push the brake again, if that makes sense..i tried about 10 times and had to use brake at least 3 times
n3v3tz is offline
post #3 of 7 (permalink) Old 12-13-2003, 09:15 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
do you have ABS? i think pressing the brake to start your car is anti-theft device related.
2014 GT
1990 300ZX TT
big mike is offline
post #4 of 7 (permalink) Old 12-13-2003, 09:33 PM Thread Starter
well that COULD be the problem, cept ive had this car for like 5 yrs and driven it everyday and tonite was the first time ive EVER had to press the brake to start it, ne other ideas
n3v3tz is offline
post #5 of 7 (permalink) Old 12-13-2003, 10:53 PM
Next time it happens, check if you're shifter is pushed all the way forward into park. I've had this happen a few times, all I have to do is push forward a bit on the shifter and the key turns.
-Rod
post #6 of 7 (permalink) Old 12-14-2003, 01:51 AM
CobraRThunder's Avatar
also...i bet you locked your steering wheel...try turning the wheel back and foth next time while turning the key.
4R70W From DirtyDog
CobraRThunder is offline
post #7 of 7 (permalink) Old 12-14-2003, 01:55 AM Thread Starter
...its kinda like when the steering wheel is locked, but it wasnt locked...
thanks for the idea though haha
n3v3tz is offline
