Anybody ever thrown a bird engine in a mustang??/ - TCCoA Forums
post #1 of 13 (permalink) Old 12-16-2003, 06:14 PM Thread Starter
I sure could use some advice and some heads up on the details on what to expect.
RobinCali is offline
post #2 of 13 (permalink) Old 12-16-2003, 07:15 PM
What year engine (I'm assuming a 3.8L), into what year mustang?
-Rod
post #3 of 13 (permalink) Old 12-16-2003, 07:57 PM Thread Starter
1995 bird to 1998 mustang....
both 3.8.
i know the mustang has coil packs. do you just swap the top piece where the distributor goes? Wiring issues?
post #4 of 13 (permalink) Old 12-16-2003, 09:21 PM
Where do you live? Some states emissions laws won't allow you to install an older model engine into a newer car.
post #5 of 13 (permalink) Old 12-16-2003, 09:30 PM
13's or Mildly Broken
RodeoJoe: [sarcams]Judging by his screen name, my guess would be California :P I could be wrong though[/sarcasm]
RobinCali: There's a guy on SCCoA who put a SC engine in a Mustang (I want to say 95) His screen name is V6Sprout. He might be able to help you. I believe he also posts on Mustang boards including www.3.8mustang.com.
-Andy "Melon"
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
post #6 of 13 (permalink) Old 12-17-2003, 09:12 AM
RGR
haha, he moved back to Illinois I think
Why would U want an older 3.8 in there?
Selling the good motor?
RGR is offline
post #7 of 13 (permalink) Old 12-17-2003, 12:22 PM Thread Starter
yes i am...the one im pullin outta the stang...
no problems. 100K on it.
post #8 of 13 (permalink) Old 12-17-2003, 12:23 PM
JustinH's Avatar
unless the motor is free, I wouldn't bother. The 98 motor is worth rebuilding, when the 95 motor is not.
JH
JustinH is offline
post #9 of 13 (permalink) Old 12-17-2003, 12:40 PM
mamberg's Avatar
that applies to V6's as well as V8's??
(What little I know about V8's dwarf's what I know about V6's)
mamberg is offline
post #10 of 13 (permalink) Old 12-17-2003, 12:42 PM
JustinH's Avatar
sorry for some reason i thought this was a 4.6 thread, carry on.
JH
JustinH is offline
post #11 of 13 (permalink) Old 12-17-2003, 07:29 PM
Basically, just pull the 98 engine out, set the two engines side by side, and swap wiring harnesses, sensors, etc. You'll likely need to reuse a few other pieces from the 98 engine, such as the upper intake. It's a very easy swap to do.
-Rod
post #12 of 13 (permalink) Old 12-18-2003, 12:36 AM Thread Starter
upper intake? why?
they look the same. its not a split port.
post #13 of 13 (permalink) Old 12-18-2003, 01:03 AM
The vacuum ports are a little different. You should be able to use the 95 upper intake, but the 98 would make it even easier. I've done the opposite swap before, a 98 3.8L from a Mustang into a 89 Cougar.
-Rod
