3.8L SC to 4.2L SC - TCCoA Forums
post #1 of 17 (permalink) Old 01-08-2004, 09:55 AM Thread Starter
PCD
Confirmed V6 Nut
3.8L SC to 4.2L SC
Hey, I've got a 3.8L SC sitting. It has 200K miles on it. It's been a PITA to sell. I am looking at doing some projects. I looked at many of the discussions of the 4.2L (Thanks PJ) and wondered besides money, what it would take to rebuild the 3.8L SC into a 4.2L SC.
I am researching a different intercooling system for the SC. I want something I can drop into a LX body.
Think we can have a technical discussion on this? I know it's a limited application, but I think I'd end up with something that is torquey as all get out, and still have decent milage.
PCD is offline
post #2 of 17 (permalink) Old 01-08-2004, 10:50 AM
well, here's a good place to start getting ideas... http://www.moranav6racing.com/stroker.html
the only problem with the 4.2, i dont believe anyone really produces a forged 4.2 crank. personally, i wouldnt build the stroker or use the 4.2 with an eaton without a forged crank. so there is one custom piece right there. -greg
glowing escape is offline
post #3 of 17 (permalink) Old 01-08-2004, 04:03 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
the ford 4.2 crank is the strongest out on the market. Anything from Morana is not worth crap on an eaton blown engine. Someone made a custom built 4.2 forged crank for 2000 dollars and used that in an sc engine. That's the only way I'd ever stroke an sc engine.
-Thomas
Thomas is offline
post #4 of 17 (permalink) Old 01-08-2004, 05:17 PM
joshbea6's Avatar
I talked to a machine shop that quoted me a price on a billet, and a forged crank, the billet was like 2100, and the forged was about 3400.
I'm debating the same upgrade to my SC motor, would love to have the low end torque, but not sure that I want to fork out the 3K for the kit, and then another 2K for the crank. with those prices I could get Coy Miller's shop to build me a Stage II engine and have it Dynoed.....and it would still be a 3.8L
joshbea6 is offline
post #5 of 17 (permalink) Old 01-08-2004, 05:24 PM
Uber Luber
Thomas's Avatar
if it were me, I'd get a 4.2 custom forged crank, forged rods and pistons from super six and rpm-mustangs, and make my own stroker kit.
Actually I plan on stroking my car to 4.1 or 4.2 using an sc forged crank and longer rods.
-Thomas
Thomas is offline
post #6 of 17 (permalink) Old 01-08-2004, 06:02 PM
You cant stroke an engine with longer rods. You'd have to change the actual stroke on the crank itself, Thomas. Having longer rods would only move the piston up in the cylinder, but the the difference between TDC and BDC(sic) would remain the same.
brokenmachines_e2 is offline
post #7 of 17 (permalink) Old 01-08-2004, 10:06 PM
Uber Luber
Thomas's Avatar
I know, i believe there is something to do with regrinding the crank itself. I have to talk to rancherlee about it more.
-Thomas
Thomas is offline
post #8 of 17 (permalink) Old 01-08-2004, 10:11 PM
Uber Luber
Thomas's Avatar
4.1L stroker using an 3.8L crank
3.58" stroke (252.7cid with a .060 overbore) and a 1.2" compression height = good
Thomas is offline
post #9 of 17 (permalink) Old 01-09-2004, 08:46 AM
i hope you werent thinking of adding boost... .060" over is quite a bit over. -greg
post #10 of 17 (permalink) Old 01-09-2004, 03:17 PM
Uber Luber
Thomas's Avatar
it's been found that .060 over is very doable and safe amount. A friend of mine with a pretty decently modded 95 sc is getting a .060 overbore.
-Thomas
Thomas is offline
post #11 of 17 (permalink) Old 01-09-2004, 04:25 PM
*pulls head out of @$$*
wasnt thinking... yea .060" is very doable...
but what i dont get is: how is re-grinding the crank going to get you .18" more stroke?
i say unless you are putting an eaton on the motor, i'd do the .060" bore with a 4.2 crank (~263.30 cid). its probably easier to get a 4.2 crank and 99+ 3.8 oil pan and just swapping that in. i think itd be more worth it. eh, oh well. -greg
post #12 of 17 (permalink) Old 01-09-2004, 05:09 PM
Uber Luber
Thomas's Avatar
I believe a new 4.2 crank from Ford is 300. I looked into it last summer and that is the number I remember hearing. You could contact Dan Newman to get a deffinate price.
it's hard to explain but imagine a large circle. Now imagine a smaller circle inside of that larger circle that has one point touching the outside edge. the center of that smaller circle is farther out than the center of the larger circle. The same principal is applied when regrinding a crank, thus giving it more stroke. Make any sense?
-Thomas
Thomas is offline
post #13 of 17 (permalink) Old 01-09-2004, 05:53 PM
joshbea6's Avatar
Has anyone ever looked into doing a group purchase for a 4.2L forged, or billet crank? I would love to see one started, but I have no idea who to even talk to anymore about getting one made.
I hate it when you lose the folder of all your contacts for your bird......I think that the X has it somewhere, and if I know her.....it has probably either been used as a cage liner, or it was burned.
joshbea6 is offline
post #14 of 17 (permalink) Old 01-09-2004, 06:05 PM
Uber Luber
Thomas's Avatar
I don't think enough people would buy it. It would still be very expensive and I believe there just wouldn't be enough interest. But if there was I might just have to jump on in.
-Thomas
Thomas is offline
post #15 of 17 (permalink) Old 01-09-2004, 07:46 PM
Sorry I gotta jump in here .060 over on ANYTHING is just asking for core shift, bent parts, holed blocks and overheating not to mention a good way to start killing HG's and warping heads with abandon.
.040 MAX on an SC block!
The 4.2 crank on SOME of the early 4.2's was forged, I forget production numbers and VIN start/stop for them tho. (srry will get back with them tho)
One could offset grind a 3.8 crank to get some stroke at the expense of strength.
Honestly if the Eaton could be adapted to the split port heads that'd be a heck of a fun ride(Kenny Brown did this on his Winstars that may be a source for lower intake manifold help... imagine geting smoked by a mid 14 sec Minivan with duals and 13" discs up front).
Zippythesquirrel is offline
post #16 of 17 (permalink) Old 01-09-2004, 08:24 PM
Uber Luber
Thomas's Avatar
Jamie Hiscoe who has a mustang with a 90sc engine is working on making a split-port lower intake to do a split-port head swap.
-Thomas
Thomas is offline
post #17 of 17 (permalink) Old 01-13-2004, 10:10 PM
"....and the cylinder bores are widened by 0.030 inches (about the limit of the 3.8's thin-wall construction)........"
Muscle Mustangs & Fast Fords January 2003 Issue
Six Therapist Article page 188
This article is a story on Morana Racing and their work on stroking the 3.8.
Canadianthunder is offline
