temperature reaching critical captain! - TCCoA Forums
post #1 of 6 (permalink) Old 01-10-2004, 09:43 PM Thread Starter
hey! my car is having bouts of fever. the temperature gauge started flucuating earlier today, so it'll go up, then down, then up then down again, then hold pretty steady in the middle. now i don't think it's headgaskets because 1) already been replaced once, 2) no coolant disaperaing, 3) over flow tank full of nice green coolant and no oil, and also because the engine isn't even hot. nor is the upper radiator hose, just midly warm. and the heater works quite well. i replaced t-stat a week or so ago w/ a 180* one, and i didn't get a good seal on the t-stat housing so it's leaking a bit there. also, when i checked to see if engine was hot or not, there were bubble coming up the overflow tank?
XR7kid is offline
post #2 of 6 (permalink) Old 01-11-2004, 02:54 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
you could have air in the system.
Thomas is offline
post #3 of 6 (permalink) Old 01-11-2004, 01:54 PM Thread Starter
any special way to get the air out?
XR7kid is offline
post #4 of 6 (permalink) Old 01-11-2004, 03:54 PM
cougarman is offline
post #5 of 6 (permalink) Old 01-11-2004, 04:21 PM
PJ-4.2L's Avatar
Send a message via AIM to PJ-4.2L
Originally posted by XR7kid
... i didn't get a good seal on the t-stat housing so it's leaking a bit there...
There's your problem.
PJ
PJ- 4.2L -
" 'DIY' was not meant for women."
PJ-4.2L is offline
post #6 of 6 (permalink) Old 01-11-2004, 08:24 PM
PCD
Confirmed V6 Nut
XR7Kid,
I hope you didn't bend the T-stat housing. Easy enough to do after you get frustrated putting in that damn t-stat.
PCD is offline
