F150 Crankshaft - TCCoA Forums
post #1 of 9 (permalink) Old 01-11-2004, 02:41 PM Thread Starter
F150 Crankshaft
Ok I was lookin on autotrader.com at at 97' F150 it says it a 4.2L but the bore is 3.18 and the stroke is 3.74 now how in the hell are the gettin 4.2 from that now my other question could I just use the crank shaft out of the f150 with my motor bore 3.8 and a stroke of 3.74 thatd really be a 4.2 right
94 SC with Built 4r70W and 408W
lx2sc is offline
post #2 of 9 (permalink) Old 01-11-2004, 10:31 PM
The bore for the 3.8 and the 4.2 are both the same at 3.81 inches.
Canadianthunder is offline
post #3 of 9 (permalink) Old 01-12-2004, 12:11 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
you could put the crank into your car, but you also needs the rods, pistons, 99+ stang oil pan, etc.
-Thomas
Thomas is offline
post #4 of 9 (permalink) Old 01-12-2004, 02:01 PM Thread Starter
Yeah I know id have to use those tings Thomas Im just saying auto trader.com has the listed as 3.18 not 3.81
lx2sc is offline
post #5 of 9 (permalink) Old 01-12-2004, 02:19 PM
Uber Luber
Thomas's Avatar
oh gotcha. Sounds like a typo then like they mixxed up 81 and 18.
I was thinking, "doesn't he already know this stuff?"
-Thomas
Thomas is offline
post #6 of 9 (permalink) Old 01-12-2004, 02:54 PM Thread Starter
Yeah I had better know that stuff I was just saying cause im sure other people look on there for some specs sometimes.
So Thomas when you gonna install your cam and stuff? which apten chip did you get the one with the free reburn
lx2sc is offline
post #7 of 9 (permalink) Old 01-12-2004, 03:05 PM
Uber Luber
Thomas's Avatar
I got my chip used from Spike. It's a delta chip so it'll work with a reburn. The cam won't go in until I get the chip reburned and I get a set of ported heads.
-Thomas
Thomas is offline
post #8 of 9 (permalink) Old 01-12-2004, 03:08 PM Thread Starter
thats cool accept how are you gonna use Spikes his ecu code must be different and they are burned specifically for that code but if you get it burnt again youll have to totally change stuff on cause I believe spike had like a 96/97 i think different tranny and all
lx2sc is offline
post #9 of 9 (permalink) Old 01-12-2004, 03:59 PM
Uber Luber
Thomas's Avatar
no he had a 94. the delta chip can be reburnt for any year car. That's what Brian Herron said.
-Thomas
Thomas is offline
