Throttle response - TCCoA Forums
post #1 of 7 (permalink) Old 01-13-2004, 02:11 PM Thread Starter
Throttle response
I seem to be having problems with throttle response. I will gas it and sometimes it will take a few seconds to kick in. Ive done pretty much all I can to tune up the engine. Ive cleaned both upper and lower intake manifolds, cleaned MAF, K&N filter, new plugs, cap, rotor, transmission filter and fluid, of course oil and filter, reset the computer everytime i made an adjustment, greased throttle cable and linkeages, and some more im probably forgeting. Could it be my tps? Am I forgeting anything?
sonicman1634 is offline
post #2 of 7 (permalink) Old 01-13-2004, 03:25 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
run some injector cleaner with your next tank of petro. clean your IAC with electrical contact cleaner.
2014 GT
1990 300ZX TT
big mike is offline
post #3 of 7 (permalink) Old 01-13-2004, 09:05 PM Thread Starter
Thanks Big Mike, I ran injector cleaner through it about a month ago. I cleaned the iac last week. When removed the fuel injectors to clean my lower intake, the injectors looked kinda rough. I might need to relace them. I was looking at them last night but damn, $40-50 per injector? That adds up to alot. I forgot that I had a code reader. Im going to put it on it tonight and see what reads.
post #4 of 7 (permalink) Old 01-19-2004, 02:41 AM
If you are interested in fuel injector servicing (rather than buying new), here are some pages I have found with good prices:
http://www.fuelin.com/page5.html
http://www.cruzinperformance.com/fuelinj.html
http://www.lindertech.com/reconinj.htm
Also, you may have problems with a sensor. I would think the O2 sensors, TPS, and ECT (coolant temp) sensor are the main suspects if nothing else fixes the problem.
Steve
S_Mazza is offline
post #5 of 7 (permalink) Old 02-05-2004, 12:14 AM
Yup. O2 sensors. I had delay problems and changing the o2 sensors fixed it.
Perch
perch is offline
post #6 of 7 (permalink) Old 02-05-2004, 10:24 AM
anomnity's Avatar
On my 87 i had a similar problem and it was my Throttle Postion Sensor.
Solid Black 1987 T-bird 5.0
anomnity is offline
post #7 of 7 (permalink) Old 02-05-2004, 12:21 PM
PJ-4.2L's Avatar
Send a message via AIM to PJ-4.2L
It's most likely the TPS, but that should throw a MIL. Check your timing.
PJ
PJ- 4.2L -
" 'DIY' was not meant for women."
PJ-4.2L is offline
