Grounding? - TCCoA Forums
post #1 of 3 (permalink) Old 01-20-2004, 12:57 PM Thread Starter
High Output Poster
91HellCat's Avatar
Send a message via AIM to 91HellCat
Grounding?
Bull and I are trying to get his 91 3.8 T-bird running correctly since we put in the new motor, but need a little help. It seems that the motor doesn't have the proper grounding since it takes so much power to start and keep the car running. What I need to know is how many ground straps are there and where do they go (connect)?
1991 Ford Mustang GT
1998 Lincoln Continental
1999 Mercury Mountaineer 5.0
91HellCat is offline
post #2 of 3 (permalink) Old 01-20-2004, 04:30 PM
I just put a motor in mine. The big ground straps are the negative cable that goes on the drivers side engine block, if you hook it to the heads, they are alluminum and dont conduct much. I made that mistake the first time without thinking. I put mine on one of the engine mount bolts to the block. Then there are the coil ground wires on the passenger side towards the front. I havent found exactly where they are supposed to go, so I bolted them together and ran a new wire from them to the block on the passenger side. somebody mentioned a ground on the back of the engine, but I never found that on either motor. Hope this helps some.
JohnNaas is offline
post #3 of 3 (permalink) Old 01-21-2004, 09:45 AM Thread Starter
High Output Poster
91HellCat's Avatar
Thanks JohnNaas. We got it figured out last night. Now if we could just figure out why it's backfiring....
