So what should I do next? - TCCoA Forums
post #1 of 5 (permalink) Old 01-22-2004, 04:57 PM Thread Starter
Roy Batty's Avatar
Iam starting a new job soon, and I am thinking of what mod to do next. i already have 96/97 exhaust manifolds, so I am debatting on doing the exhaust system or and udp? Which would yield more gain? It looks like the ASP pulley would be cheaper, but opening the exhaust up would probably help with gas milage. Thnaks for your opinions.
Everyday of my life is a constant fight, between wrong and right.
When there is no grass on the field, go around back and play in the mud.
Roy Batty is offline
post #2 of 5 (permalink) Old 01-22-2004, 05:59 PM
IMO, i'd go with the exhaust. Opening up the exhaust on this engine seems to help out quite a bit. Just don't go overboard and kill the low end.
My XR7 2004 is offline
post #3 of 5 (permalink) Old 01-23-2004, 10:54 AM Thread Starter
Roy Batty's Avatar
Yeah. I have that planned out. 2 1/4 downtubes from the manifolds to the cats(replacement but not hi flo cats). Same 2 1/4 piping from the cats to the flowmaster muffler, and 2 1/2 out the back. I'll omit the muffler out the back. THat should work out ok.
post #4 of 5 (permalink) Old 01-23-2004, 03:22 PM
Which flowmaster are you going to use?
Are you going to run duals or a single pipe?
post #5 of 5 (permalink) Old 01-24-2004, 12:17 AM Thread Starter
Roy Batty's Avatar
Not sure the specific flowmaster. It is baffled to reduce noise though. I am looking for good flow, with minimal sound. A single pipe is my goal.
