3.8 sc into fox body 88 cougar - TCCoA Forums
post #1 of 17 (permalink) Old 01-24-2004, 12:52 AM Thread Starter
Hey guys has anyone here done the 3.8 sc engine swap to a fox body 3.8l car. I have a 1988 cougar 3.8l and I wanto to swap to the 3.8 sc engine how hard would it be to do this swap and anything else I need thanks guys lmk.
88cat is offline
post #2 of 17 (permalink) Old 01-24-2004, 04:25 PM
TBird232ci's Avatar
Send a message via AIM to TBird232ci
its possible...but not worth it
basically, youd need a S/C parts car, wiring harness, all the piping, intercooler, computers, vacume lines, EVERYTHING
youd be better off going 5.0 if you want to do an engine swap
TBird232ci is offline
post #3 of 17 (permalink) Old 01-24-2004, 05:28 PM Thread Starter
I thought about this and I wanna go 3.8 sc so I will need to swap everything from the sc right. I found my junker car already and its close to my house but I dont know how much they want for it. Thnaks anything else I need to know and has anyone done this swap yet thanks lmk.
88cat is offline
post #4 of 17 (permalink) Old 01-24-2004, 07:20 PM
Pedal Faster
Josh_Keady's Avatar
You'll have to make some custom intercooler plumbing, might have to stretch a couple of wiring harnesses, but luckily, the Fox cars are pretty accepting of swaps like these. Plenty of room under the hood, used the same mounts and transmission as the MN-12, definitely not impossible.
Josh Keady
Josh_Keady is offline
post #5 of 17 (permalink) Old 01-24-2004, 08:05 PM Thread Starter
What Josh_Keady the tranny and mounts wont work on the fox body or what also for the driveshaft which one will work thanks guys lmk.
88cat is offline
post #6 of 17 (permalink) Old 01-24-2004, 09:48 PM
TBird232ci's Avatar
for the most part, you can just relocate many fenderwell and firewall mounted things for the harness to reach
the intercooler piping will definatly have to be custom, it my buddy comes by, maybe i can park side to side and look at what things would take to work
the engine mounts are the same, but im not sure about transmission, is the MN12 tranny and fox tranny the same length, if it is, it should mount right up no problem, and you should be able to use your stock driveshaft, if not, you could use your stock tranny, but it wont last too long
if you have the money and time, give it a shot, id love to see it done
post #7 of 17 (permalink) Old 01-24-2004, 09:54 PM
Pedal Faster
Josh_Keady's Avatar
As long as it's pre-'93, they use the same AOD tranny. Only difference is the shift linkage.
Josh Keady
post #8 of 17 (permalink) Old 01-24-2004, 09:56 PM
TBird232ci's Avatar
and since the fox is a column shift, thats another pain in the a**, definatly convert to floor shift, and do true dual exhaust
post #9 of 17 (permalink) Old 01-24-2004, 09:57 PM
TBird232ci's Avatar
and also pick up a chiltons or haynes for the same year SC youd pick up as a parts car, the wiring diagrams will definatly help, along with some general info
post #10 of 17 (permalink) Old 02-18-2004, 10:29 PM Thread Starter
Hey guys so a 93 and before have the same lenght tranny so I can use it. Also is it true what they say at SCCoA that with headers duals no catalic converters and thick pipe will give me like 75hp. thanks anyother things I need to know thanks lmk
88cat is offline
post #11 of 17 (permalink) Old 02-19-2004, 07:35 AM
Pedal Faster
Josh_Keady's Avatar
I don't know about 75 hp, but it will certainly make a larger difference on an SC'd motor.
Josh Keady
post #12 of 17 (permalink) Old 02-19-2004, 10:40 PM Thread Starter
Hey guys Is it true that the 94/95 sc t-birds had the AOD the same as the 3.8 NA AOD. thanks lmk
88cat is offline
post #13 of 17 (permalink) Old 02-19-2004, 11:33 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
No they have an electronically controlled 4r70w
Thomas is offline
post #14 of 17 (permalink) Old 02-21-2004, 12:23 AM Thread Starter
All automatic Super Coupes and XR7’s from 89-93 used the Ford AOD
I just read this on SCCoA guys Is this true thanks lmk
88cat is offline
post #15 of 17 (permalink) Old 02-21-2004, 01:58 AM
Pedal Faster
Josh_Keady's Avatar
83-93 = Totally mechanical AOD
94-97 = Electronically controlled 4R70W
Josh Keady
post #16 of 17 (permalink) Old 02-21-2004, 01:50 PM Thread Starter
So guys I was asking if some supercoupes had the aod cause If the 4R70W does not fit with the driveshaft I have to use my aod and If It would handle the power. Do you guys think my aod tranny from 1988 3.8 NA will handle the 3.8sc a guy on cool cats forum did it and he used the 3.8 aod tranny NA and it is holding up so far. But If I use the aod I also want to mod the engine in the future and if the aod will handle the punishment. thanks lmk
88cat is offline
post #17 of 17 (permalink) Old 02-21-2004, 06:02 PM
Uber Luber
Thomas's Avatar
YES ALL 1989-1993 supercoupes had the AOD. ALL 1994-1995 supercoupes had the 4r70w.
You can use your transmission but don't expect it to last very long at all. Especially if you're going to mod the engine.
-Thomas
Thomas is offline
