Help! Constant Backfire on 89LX 3.8 - TCCoA Forums
post #1 of 12 (permalink) Old 01-26-2004, 05:12 PM Thread Starter
Angry Help! Constant Backfire on 89LX 3.8
Ok, I've been through everything that I can think of in 15degree weather.
The other day while driving on the highghway my bird starting backfiring into the intake, pretty consistantly. It does this at idle and horribly upon acceleration.
It sounds like a constant popping coming from the intake (Something Like a Firecracker).
Code Scanner comes up with nothing.
Compression appears to be good.
I noticed a Black Soot type of matter coming from the exhaust pipe.
This happens both hot and cold but noticably more pronounced when hot.
Any Ideas?
Scott
great_scott is offline
post #2 of 12 (permalink) Old 01-26-2004, 10:28 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
black soot is probably carbon. sounds like its time for a tune up.
2014 GT
1990 300ZX TT
big mike is offline
post #3 of 12 (permalink) Old 01-27-2004, 02:26 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
sounds like valve seals
try some of this stuff....
-Thomas
Thomas is offline
post #4 of 12 (permalink) Old 01-28-2004, 04:37 PM Thread Starter
Thumbs up
Ok, here's a new one.
Don't know how, don't know why. But a rocker arm fell off.
Go Figure...
post #5 of 12 (permalink) Old 01-28-2004, 04:44 PM
Uber Luber
Thomas's Avatar
Go Figure...
Did you try the seafoam? Seafoam has been known to reinstall rocker arms. That's how great that stuff works! ok not really.
I had a rocker arm fall off once too, but it wasn't just a backfiring I could hear the clatter of that thing inside the valve covers. And I had to limp home at 5mph.
-Thomas
Thomas is offline
post #6 of 12 (permalink) Old 01-28-2004, 08:07 PM Thread Starter
No, believe it or not the way everything came apart, the rocker wedged itself in between the valve cover and the oush rod which kept the rod up and out of the way of the lifter so there was not the normal "tap tap tap" that you would think that you would hear by the push rod banging inbetween the lifter and the valve cover.
As for limping home, that I did, but was able to hold it at 15-20 mph.
Scott
post #7 of 12 (permalink) Old 01-28-2004, 08:09 PM Thread Starter
Question
BTW, forgive my ignorance, but what is seafoam?
post #8 of 12 (permalink) Old 01-28-2004, 08:17 PM
Uber Luber
Thomas's Avatar
it takes out carbon buildup in your engine and exhaust. I put it in through a vacuum hose in my upper manifold to clean out that part too. Works wonders sometimes.
-Thomas
Thomas is offline
post #9 of 12 (permalink) Old 01-31-2004, 02:50 AM
Wow, I also had a rocker arm fall off. I guess a bolt broke. That was a couple years ago ... the repair bill was $90 in labor, $3 in parts. It felt scary ... this vibration slowly built and built. I could feel hits in the gas pedal, and then the car started to lug, and it was bad. I was on the highway at the time. Well, I was glad to escape with only $100 gone. The guy who fixed it seemed cool.
Steve
S_Mazza is offline
post #10 of 12 (permalink) Old 02-20-2004, 02:40 PM
Ya Seafoam can work wonders if your engine is carboned up, but you will smoke out your entire neighborhood in the process. I use it in my outboards twice a year and you would swear there is a forrest fire nearby. Last fall, I de-carboned the engine just upwind from the a$$hole who throws rocks in the water when we fish in "his" cove. Man, I'll bet you could have heard him b*tching a half a mile away! Just for payback, I did an extra good job. That area was so full of dense bluish white smoke, the boat traffic had to slow down to a crawl.
1988 Cougar 3.8
1995 40th Anniversary Edition 4.6
Wingnutt is offline
post #11 of 12 (permalink) Old 02-22-2004, 06:59 PM
I've been thinking about running some seafoam through one of my engines, but I'm concerned about all of the carbon and debris going through the catalytic convertors. What is everyone's take on this subject?
-Rod
post #12 of 12 (permalink) Old 02-22-2004, 07:13 PM
Uber Luber
Thomas's Avatar
carbon won't hurt the converters. The seafoam will probably clean those out too! That stuff is miracle liquid!
-Thomas
Thomas is offline
