Check engine,Light - TCCoA Forums
post #1 of 10 (permalink) Old 01-27-2004, 09:45 PM Thread Starter
Unhappy Check engine,Light
I have a Question ,please help... 3.8 ,V6 92. they did Head gasket but the
Check Engine is On ,this car is Running strong,i had a trip of 400 miles ,beside the
Engine light, there is an strange sound that comes from the Right side of the engine,
when I start cold, is like some thing is lose ,later that sound go quieter,
There a possibilite of the engine is DYing on me ,
Marlon, Thank you
kilimanjaro is offline
post #2 of 10 (permalink) Old 01-27-2004, 10:31 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
im gonna guess bad o2 sensors. blown HG's almost always takes them out.
2014 GT
1990 300ZX TT
big mike is offline
post #3 of 10 (permalink) Old 01-27-2004, 10:40 PM
Sounds like you need to pull the codes to me.
93SC is offline
post #4 of 10 (permalink) Old 01-28-2004, 02:13 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
Here's how to check engine codes on your year of car.
1 - Locate the EEC TEST harness and pull it out of it's mounting hole behind the passenger shock tower.
2 - Bend a paper clip in a U shape in place it in the two indicated plugs on the two harnesses
3 - go inside cab of car and turn key to the accessory position but don't start the car. (key on engine off)
4. the "check engnie" light will flash once (I believe) and this means the car has gone into code reader mode.
5. Then the light will flash again, it's kind of like morse code in numbers. there are several flashes to indicate the number, then a pause for a few seconds, then another several flashes to indicate the next number
example: 3 flashes - pause - 2 flashes - pause - 4 flashes = code # 324.
There will be an even large pause between codes if there is more than one code stored. Check the codes or ask if you need more help on how to do it. Then once you get the codes come back and post what they are, I'll let you know what they are and I'll throw in my advice as a bonus
-Thomas
Thomas is offline
post #5 of 10 (permalink) Old 01-28-2004, 07:54 PM
thomas, can you tell me how to pull the codes and not get confused with the blinking light?????is this even possible?? im getting some really weird #'s here.thanks.
GC
bigbird94 is offline
post #6 of 10 (permalink) Old 01-28-2004, 08:12 PM
Uber Luber
Thomas's Avatar
not unless you want to go to a shop and pay 45 bucks for them to do it. It can take a while to get used to so don't sweat it.
What numbers did you get?
-Thomas
Thomas is offline
post #7 of 10 (permalink) Old 01-28-2004, 08:15 PM
Uber Luber
Thomas's Avatar
what I usually do is get a piece of paper and pen, make sure you've got a flat surface like a clipboard or something of the like. this part is tricky hehe...as the number flash out scribble them down without looking down. If you look down it can confuse you and you might miss some of the flashes. Then sort it out after you're done. That's what I do.
-Thomas
Thomas is offline
post #8 of 10 (permalink) Old 01-28-2004, 08:52 PM
yeah when i was pulling them i looked down but i then tried your ingeneous way of not looking down. cant figure out why i couldnt think of that . i got the whole thing figured out anyways. i got the haynes manual which had the codes for me.
GC
post #9 of 10 (permalink) Old 01-28-2004, 10:27 PM
Uber Luber
Thomas's Avatar
GC
Awesome. Glad my genius techniques could be of help to you
So what was it?
-Thomas
Thomas is offline
post #10 of 10 (permalink) Old 01-28-2004, 11:38 PM
it ended up being a few things. both o2's were not switching, and there was something regarding egr so i went huntin' for a prob around the egr and found the hose between the transducer and the manifold to be blocked so i un blocked it.i gtg
GC
