=( for my 3.8 - TCCoA Forums
post #1 of 11 (permalink) Old 02-11-2004, 03:15 PM Thread Starter
anomnity's Avatar
=( for my 3.8
It has come to my knowlege that #2+6 cylinders are only getting 50psi after 3 pump on the compression test. So i removed the valve cover and inspected the rocker arms and pushrods and they looked fine. Seeing this I began to remove my timming cover to inspect the timming chain and alignment. And today i've finished that and saw that everything was alright.
Seeing all of this the only thing left for me to do is remove the head(s). Taking one off i might as well do the other one. Since I'm getting that intake(s) and T/B from CatBird, i figures since the intakes are coming off i should replace the H/g's anyways seeing how the motor has quite a few miles on it (210,000). So the striped bird is going to be out for awhile.
Wish me luck! I'll need it.
Solid Black 1987 T-bird 5.0
anomnity is offline
post #2 of 11 (permalink) Old 02-11-2004, 03:20 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
That sucks man. Has Chrometip sold his heads yet? They're pretty cheap. If you can get a hold of them that'd be a good thing to do while the heads are off anyway.
-Thomas
Thomas is offline
post #3 of 11 (permalink) Old 02-11-2004, 03:34 PM Thread Starter
anomnity's Avatar
I dunno if he has. Ill PM him and see tonight.
anomnity is offline
post #4 of 11 (permalink) Old 02-11-2004, 03:35 PM
AEDM8's Avatar
*cough*
I believe so.
AEDM8 is offline
post #5 of 11 (permalink) Old 02-11-2004, 04:00 PM
Uber Luber
Thomas's Avatar
oh sh*t...forgot about that. Sorry
Thomas is offline
post #6 of 11 (permalink) Old 02-11-2004, 09:51 PM
AEDM8's Avatar
It's cool, I'll just slap you when we meet this spring/summer.
AEDM8 is offline
post #7 of 11 (permalink) Old 02-11-2004, 11:11 PM Thread Starter
anomnity's Avatar
What did the hand say to the face? SLAP!!!
What are the best H/G to use when doing this. Are Ford's OEM brand good or should i go with a well trusted brand?
I can fix the heads if they are f'ed up. so its no big deal, just time consumming.
anomnity is offline
post #8 of 11 (permalink) Old 02-11-2004, 11:27 PM
Uber Luber
Thomas's Avatar
I'd personally go with fel-pro. I've heard Ford is making some high quality HG's now but I have yet to see them so I can't really give my opinion on them yet.
-Thomas
Thomas is offline
post #9 of 11 (permalink) Old 02-12-2004, 03:49 AM
I have only used the Fel-pro, which has lasted 6 years / 35,000 miles so far. The newer Ford gaskets are a multi-layer steel gasket, which should be much better than the old Ford ones. I don't really know how it stacks up against the Fel-pro. To its credit, my mom's 96 Windstar has lasted 100,000 miles on its original head gaskets (as far as I know ... haven't taken off the heads.) Fel-pro has a steel gasket listed for 97+ 3.8s, but I don't know if it fits any Thunderbirds. Morana V6 Racing sells some different types of metal gaskets: http://www.moranav6racing.com/parts2.html RPM-Mustangs also sells gaskets: http://www.rpm-mustangs.com/ocat/engine.html This is a good place to look for advice on which to choose, but you could also contact someone like those 2 vendors and ask what they recommend for your particular application (and if the later gaskets will fit).
Steve
S_Mazza is offline
post #10 of 11 (permalink) Old 02-12-2004, 01:55 PM Thread Starter
anomnity's Avatar
I went ahead and ordered some from fel-pro. I got the gasket kit and head bolt sets.
thanks for the info guys!
anomnity is offline
post #11 of 11 (permalink) Old 02-12-2004, 02:45 PM
Uber Luber
Thomas's Avatar
newer model gaskets won't work, the coolant passages are different.
-Thomas
Thomas is offline
