HELP! big problem - TCCoA Forums
post #1 of 16 (permalink) Old 02-12-2004, 09:32 AM Thread Starter
SCsmo's Avatar
HELP! big problem
ok well, here goes, went to start my car yesterday. when i turned the key, it cranked once, the i could hear the engine turn slowly, and after a couple seconds it finally started. then later in the day, it did the same thing, when i went to drive, the engine was vibrating, adn felt very uinder powered. also, there was a massive trail of blue/white smoke out of the tail pipes, i mean MASSIVE. so i pulled over and shut it off. i then turned it on and it did the same thing, only it ranfor about 5 seconds and stalled, and now it wont start. help! i was thinkin it might be a hg, but that wouldn't cause it to not run. so maybe a spun bearing? idk, just lookin 4 help.
o, also it was over heating pretty bad the other day, the thermostat wasn't opening so i had to change it.
01- mustang cobra- lazer red -bbk o/r x pipe w/ 40 series, JLT, waiting to install 4.10's
04 ram- ya, its a hemi- [email protected] -sold!!
92 tbird sc- sold!!!- almost made it to the 60ft mark
newest sales rep at Herb Chambers Ford in Braintree, MA, pm me for info
SCsmo is offline
post #2 of 16 (permalink) Old 02-12-2004, 11:13 AM
Send a message via AIM to stiffler197
sounds like a head gasket. my mothers taurus did the dame thing u described two years ago. luckily i was like a hundred feet from teh shop my dad worked at so i could push it into a bay
stiffler197 is offline
post #3 of 16 (permalink) Old 02-12-2004, 01:39 PM
A headgasket could very easily prevent the engine from turning over if the engine has become hydro-locked. A spun main bearing could do the same. Try turning the engine over by hand with a breaker bar. If it won't turn, do the same thing, only with the spark plugs removed this time. If it turns, then the engine was likely hydro-locked (headgaskets). If it still won't turn, then you probably have a spun bearing. If the engine was hydro-locked, you can plan on seeing something like this:
-Rod
post #4 of 16 (permalink) Old 02-12-2004, 09:36 PM Thread Starter
SCsmo's Avatar
o ok, um when i take the spark plugs out, do i turn the car on and c if it cranks over? or do it by hand w the breaker bar?
SCsmo is offline
post #5 of 16 (permalink) Old 02-12-2004, 09:57 PM
I would recommend doing it by hand. You have a lot more control over it that way.
-Rod
post #6 of 16 (permalink) Old 02-12-2004, 10:09 PM Thread Starter
SCsmo's Avatar
o, ok. i'll have to try that in the morning. yes another long car project!
SCsmo is offline
post #7 of 16 (permalink) Old 02-13-2004, 01:34 AM
i wonder why the HG's go left and right on the 3.8's never happens with any of the 5.0 guys
trife86 is offline
post #8 of 16 (permalink) Old 02-13-2004, 08:28 AM Thread Starter
SCsmo's Avatar
simple, iron block, aluminum heads, and there isn't really too much between the cylinders and the coolant passages
SCsmo is offline
post #9 of 16 (permalink) Old 02-15-2004, 02:05 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
That combined with the OEM head bolts that were idiotically designed to flex and move around to compensate for the different expansion/contraction rates of the two different types of material used. It's like putting a piece of paper between two pieces of sandpaper and rubbing. The paper is going to be gone pretty quick.
-Thomas
Thomas is offline
post #10 of 16 (permalink) Old 02-15-2004, 05:48 PM
what are ways of prolonging the HG life besides making sure the car isnt running very hot and beating on it ?
trife86 is offline
post #11 of 16 (permalink) Old 02-15-2004, 06:24 PM
Uber Luber
Thomas's Avatar
fel-pro gaskets, ARP head studs, 180* t-stat, flush coolant once or twice a year.
-Thomas
Thomas is offline
post #12 of 16 (permalink) Old 02-16-2004, 03:11 PM Thread Starter
SCsmo's Avatar
mmm, hydrolocked. this should b fun
SCsmo is offline
post #13 of 16 (permalink) Old 02-16-2004, 03:15 PM Thread Starter
SCsmo's Avatar
you know, between my friends and i, we own 6 mn12s (4 cougars 2tbirds) and of all of them, 4 have blown headgaskets, and y haven't the other 2? simple... V8!
SCsmo is offline
post #14 of 16 (permalink) Old 03-01-2004, 11:00 PM Thread Starter
SCsmo's Avatar
o, so i found out.........drum role please.........blown hg's!, like we all new, but it gets better........a cracked head!!!
SCsmo is offline
post #15 of 16 (permalink) Old 03-01-2004, 11:18 PM
Uber Luber
Thomas's Avatar
very nice. sorry to hear that! Hey, good excuse for ported heads right?
-Thomas
Thomas is offline
post #16 of 16 (permalink) Old 03-02-2004, 07:30 AM Thread Starter
SCsmo's Avatar
well, at the very least. i think i'm puttin a remanned in.....fun
SCsmo is offline
