Lazy engine - TCCoA Forums
post #1 of 7 (permalink) Old 02-19-2004, 12:12 AM Thread Starter
Question Lazy engine
My 89' N/A 3.8l seems to be a tired little guy. Heres the problem. If i go into WOT the engine just...doesnt do much. Its as if its just lazy. It just gives a bit of a rumbling noise. I thought perhaps my cat might have been clogged and there was just a restriction holding the engine back, but I ran the car with open headers and it still performed the same way only a bit louder. I havent had time to check the EGR diaphram or solenoid yet, but ive heard fords are notorious for EGR problems. Any input would be greatly appreciated.
PA_MN12 is offline
post #2 of 7 (permalink) Old 02-19-2004, 11:40 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
Try checking the IAC and TPS voltages for lower voltage than required to run properly. You'll need a haynes or chilton's manual to find the voltages. Sounds to me like something related to that though.
-Thomas
Thomas is offline
post #3 of 7 (permalink) Old 02-19-2004, 11:51 PM Thread Starter
Ive checked the TPS before, and its voltage was normal all through the range of travel, as for the IAC do you think that would effect drivability? Thanks for the advice though. Ill see if the stepper motor is working properly.
PA_MN12 is offline
post #4 of 7 (permalink) Old 02-19-2004, 11:57 PM
Uber Luber
Thomas's Avatar
It's worth a shot. You never know what weird things cars will do.
Thomas is offline
post #5 of 7 (permalink) Old 02-20-2004, 12:43 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
sounds like you may need a tune up. just my .02.
2014 GT
1990 300ZX TT
big mike is offline
post #6 of 7 (permalink) Old 02-20-2004, 12:58 AM
Uber Luber
Thomas's Avatar
Way ta go Mike!
Thomas is offline
post #7 of 7 (permalink) Old 02-22-2004, 01:07 AM
Well, I would scan the computer for codes first. That might help narrow it down.
If that doesn't help, I would go about things the old-fashioned way. Process of elimination. You checked the TPS, which is good. Check the ECT (coolant temp sensor), your BAP sensor, O2 sensors. Also, you might have a fuel problem. It could be a dying fuel pump, or clogged injectors, or maybe a bad FPR. Timing could be off, I guess. Check plugs and wires, and maybe inspect the distributor (cracked cap, or the rotor could wear out) and coil.
edit: The fuel filter could be clogged. Oh yeah, and you might want a compression test if nothing else helps.
Steve
S_Mazza is offline
