Code Reader - TCCoA Forums
post #1 of 16 (permalink) Old 02-22-2004, 12:41 PM Thread Starter
Code Reader
Hey I got the following COdes from the Actron Code Reader
157
159
WHat do these mean?
AHicks324 is offline
post #2 of 16 (permalink) Old 02-22-2004, 05:44 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
157 - Manifold Air Flow sensor fault, low voltage
159 - Manifold Air Flow sensor fault, above or below normal
Thomas is offline
post #3 of 16 (permalink) Old 02-23-2004, 05:49 AM Thread Starter
SO should I just unplug it and see how things work?
or should I just go ahead and replace the thing?
post #4 of 16 (permalink) Old 02-23-2004, 07:05 AM Thread Starter
Im going to go ahead and clean the thing
http://www.tccoa.com/articles/intake/mafclean.html
I found this on the board. It seems everyone has the same problems, and by now all the answers are already availiable!!! Thanks guys for providing feedback on these issues. Im saving time and money. Glad I joined this board.
post #5 of 16 (permalink) Old 02-23-2004, 12:20 PM
Uber Luber
Thomas's Avatar
I've never seen a dirty maf sensor throw codes before but it's worth a try to clean it, since it's free and all. If that doesn't work, unplug the maf and see if it runs better than it is right now. If it runs better with the maf unplugged, then it's time to replace it.
-Thomas
Thomas is offline
post #6 of 16 (permalink) Old 02-24-2004, 09:49 AM Thread Starter
I unplugged it and its gving me the same problems, but a little better I guess. How long can I ride with it unplugged, I can't replace it till Friday. But should I get some Mercon V??
post #7 of 16 (permalink) Old 02-24-2004, 10:56 AM
Uber Luber
Thomas's Avatar
Don't drive around with it unplugged, it screws the air/fuel mixture up. Just get the sensor replaced as soon as you can.
-Thomas
Thomas is offline
post #8 of 16 (permalink) Old 02-24-2004, 04:22 PM
Did you try cleaning it? I never heard of it being dirty enought ot throw codes either, but it's cheap.
93SC is offline
post #9 of 16 (permalink) Old 03-04-2004, 05:26 PM Thread Starter
I cleaned it and it didn't work, I then went to the junkyard and got one outta a 94 T Bird. The light went off and everything works fine now. I do get the occasional shudder every once in a while. Like when the engine overloads. Like if I roll up the windows and crank the heat and have the radio up then mess with the power seat. What could be the cause of this?
post #10 of 16 (permalink) Old 03-04-2004, 08:27 PM
Uber Luber
Thomas's Avatar
uuuh, you're draining the battery and the alternator can't keep up. don't do that anymore.
-Thomas
Thomas is offline
post #11 of 16 (permalink) Old 03-11-2004, 02:33 PM Thread Starter
my battery is on the charger as of now
post #12 of 16 (permalink) Old 03-12-2004, 07:25 AM
PCD
Confirmed V6 Nut
Thomas,
with a 95, doesn't he have the biggest OEM alternator Ford put on the these cars? Maybe he should have the alternator checked for bearings problems and to see if it is functioning properly.
PCD is offline
post #13 of 16 (permalink) Old 03-12-2004, 03:38 PM
Uber Luber
Thomas's Avatar
95 sc's had the highest output alternator of the mn12's. 130amp I believe. It could be the regulator on the back of the alternator.
-Thomas
Thomas is offline
post #14 of 16 (permalink) Old 03-30-2004, 08:26 AM Thread Starter
does anybody have a alternator replacement wakl through. I got a new one, and need help getting it in.
post #15 of 16 (permalink) Old 03-30-2004, 11:58 AM
Uber Luber
Thomas's Avatar
It's really easy actually.
1. Disconnect battery.
2. Find the tensioner pulley down in the lower passenger side of the engine, then put a wrench or ratchet on it (I believe it's 18mm but not possitive) and pull up on it reeeeeally hard, then unstrap the belt.
3. Then unbolt the 2-3 bolts (can't remember how many) holding the alternator on
4. disconnect the wiring
5. reverse instructions for putting in the new one.
Thomas is offline
post #16 of 16 (permalink) Old 03-31-2004, 10:41 AM Thread Starter
i got to step 4 i think, i took out 2 bolts so far, and the alternator is loose but is held by some bolt i on the bottom. i took the long one out, and i can't pull it off. also about the wiring i took off the first 2 little ones, but the big black and yellow wire is not coming off, and i don't want to strip the rubber around it.
