Speed bump on heads. - TCCoA Forums
post #1 of 11 (permalink) Old 02-22-2004, 01:54 PM Thread Starter
anomnity's Avatar
Question Speed bump on heads.
Almost done with removing my heads. Its taken me this long because of work, school, and this shi** weather we've been having here.
But the problem i ran into is trying to remove the bottom head bolts near the exhuast manifold. I'm sure i can get the drive side manifold completely off easily, but the passenger side is a whole other story. The top bolt that connects the manifold to the pipe is impossible to get to. So i was wondering if removing the stater would help me or is there some other way that would be easier. Also, if the driver side isn't as easy, is there a trick to it as well.
I'm out of options. I tried having someone pry alittle on the manifld to move it just enough to get the socket on, but there just isn't enough free play and I don't want to bend or warp anything.
And help would be greatly appreciated. Thanks guys!
Solid Black 1987 T-bird 5.0
anomnity is offline
post #2 of 11 (permalink) Old 02-23-2004, 12:38 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
swivels are your friend. about 5 bucks at sears for a craftsman swivel. they saved my life taking off my exhaust. Okay well not my life, but they sure helped a lot.
-Thomas
Thomas is offline
post #3 of 11 (permalink) Old 02-23-2004, 09:38 AM Thread Starter
anomnity's Avatar
Alright, thanks Thomas. I'll try this and take the starter off for a little extra room.
anomnity is offline
post #4 of 11 (permalink) Old 02-26-2004, 04:59 PM
Uber Luber
Thomas's Avatar
How's it coming along?
-Thomas
Thomas is offline
post #5 of 11 (permalink) Old 03-01-2004, 11:03 PM Thread Starter
anomnity's Avatar
Everythings is clean and ready for re-assmebly. And man were my heads dirty. I polished the heads, re ground the valves and cleaned the seats up. I'm going to have to borrow a torque wrench from a buddy so i can get the heads torqued and the rocker arms. I'm going to them put everything i need on it to start it w/out the accesories. (starter, exhaust manifolds and pipe, intake, fuel rail, etc.) I'm mainly doing this to check to see if there is going to be any problem. I don't doubt my work, just taking precautions.
anomnity is offline
post #6 of 11 (permalink) Old 03-07-2004, 04:19 AM Thread Starter
anomnity's Avatar
Heads and rocker arms are on now. all i got left is teh exhaust, starter, fuel rail and intakes to et it ready for testing. If all goes well i should have it on the road by tuesday since it is springbreak for me. yYYYYAAAYYY
anomnity is offline
post #7 of 11 (permalink) Old 03-09-2004, 08:11 PM
Awesome. I hope all goes well. Getting something fixed is such a great feeling.
By the way, when I fixed this on my car, I started it up and it started spewing coolant out the tailpipe. I mean several quarts. The leak was fixed, but all that coolant was sitting in the cats, resonator, and mufflers. So be prepared for that possibility. If I had it to do over, I would have put some kind of pan down to catch that instead of letting it run all over the driveway and into the gutter. Eeeeewwww ...
Steve
S_Mazza is offline
post #8 of 11 (permalink) Old 03-09-2004, 11:57 PM Thread Starter
anomnity's Avatar
My H.G. was leaking by the combustion chamber. so i doubt ill have coolant come out. but who knows...
anomnity is offline
post #9 of 11 (permalink) Old 03-10-2004, 11:46 AM Thread Starter
anomnity's Avatar
well i got my intake on and most of my wiring connected. My aior condit. and p.s. brackets are on. I have to order a new set of sealers for my injectors and a couple of vaccum hose pieses for the ones that cracked and i shoul dbe going good.
by the mlooks of my work schedule, i should have it almost done on friday.
anomnity is offline
post #10 of 11 (permalink) Old 03-10-2004, 12:01 PM
Uber Luber
Thomas's Avatar
cool. coming along pretty nicely for ya.
Thomas is offline
post #11 of 11 (permalink) Old 03-15-2004, 01:45 AM Thread Starter
anomnity's Avatar
well it's all back together.(atleast motor wise, alt. and stufff are still off) and im trying to get it to start up. I know it's the timming i Just didn't have enough time to work on it. and plus the stupid dist. on has so much room to move. I got it to spit a little bit, but not fully run. I should have it done by tuesday.
anomnity is offline
