Question about engines - TCCoA Forums
post #1 of 10 (permalink) Old 02-25-2004, 05:15 PM Thread Starter
I was wondering if a 3.8 Mustang could be swapped with the regular stock 3.8 n/a Cougar engine. And if so could you use the stock Cougar Tranny or would you have to go with the mustang tranny? Or could you replace it with 2.3 ltr 4 banger mustang engine?
P1a5tic Ph0rk is offline
post #2 of 10 (permalink) Old 02-25-2004, 06:31 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
not sure about the 3.8 stang motor, but IMO i would swap in a used low mileage 5.0 out of bird or fox body stang. both use AOD trannies.
2014 GT
1990 300ZX TT
big mike is offline
post #3 of 10 (permalink) Old 02-25-2004, 07:57 PM Thread Starter
If I did replace it with an 5.0 i'd have to replace alot more right?
post #4 of 10 (permalink) Old 02-25-2004, 08:12 PM
Motorboatin' SOB
big mike's Avatar
pretty much, you would need almost everything under the hood, as well as the 8.8 pumpkin to compensate for the increase in power. theres more, i just covered the big parts. better to have a donor car. do a search for 5.0 swap.
2014 GT
1990 300ZX TT
big mike is offline
post #5 of 10 (permalink) Old 02-26-2004, 07:03 AM Thread Starter
There is a 5.0 Cougar the the junk yard not far from here that has everything including the motor, I don't think it was in any collision or anything but someone tore the dash out so I won't know how many miles are on it. But from what I saw the Cougar had everything on it.
post #6 of 10 (permalink) Old 02-26-2004, 04:57 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
Depends on the year of the stang and the year of the cougar. It all depends on DIS and wether it's EEC-IV or EEC-V. That will determine how much work is involved.
Mike, 94-95 5.0's had AODE
-Thomas
Thomas is offline
post #7 of 10 (permalink) Old 02-26-2004, 05:59 PM
Basically, a 94-98 Mustang 3.8L will swap right into the 3.8L N/A MN12. It is a very easy swap, you just reuse all sensors, ignition system, etc, that was stock on your 3.8L N/A MN12. However, there isn't much, if any, difference in horsepower/torque between the two engines.
The 99+ Mustang 3.8L engine will also swap into the 3.8L MN12 without too many headaches. It is a more complex swap than the 94-98 Mustang 3.8L, however. If your 3.8L N/A MN12 already has DIS, the swap is much easier. Installing DIS isn't much fun, but I've done it on two MN12's now, so it sure isn't impossible.
-Rod
post #8 of 10 (permalink) Old 03-05-2004, 12:58 PM
PCD
Confirmed V6 Nut
If you got the money, why not put in a 4.2L? Less extra to swap and 210 HP from a N/A motor. It's basicly the same block.
PCD is offline
post #9 of 10 (permalink) Old 03-05-2004, 09:03 PM
Very possible, somewhat easy to do,
I did a 98 Mustang engine in my 94 3.8, (had to do some wire cutting a splicing otherwise a direct swap)
In your case if you go with a Mustang engine with DIS, you will have to reuse some of the parts off of your 90' 3.8 to make it with a Distributor, unless you get a computer and wiring from a 94-95 3.8 Cali Emissions (good luck finding one for cheap). anyways, you can reuse your transmission it will bolt right up, you will have to do a lot of sensor swapping and may have to swap you lower intake (i did, as the mustang engine did not have the Air Charge sensor bung),
oh, yeah, NO 4 Banger (probably wouldn't even move the bird)
KewlBird is offline
post #10 of 10 (permalink) Old 03-06-2004, 12:33 AM
Uber Luber
Thomas's Avatar
Actually if you want to convert to DIS you don't need a new EEC. Rod can vouche for me on that one. He helped me out with a wiring diagram to wire in DIS on a distributor EEC. Of course you'd need a chip w/ a program to run the DIS but that's not hard to get a hold of (unlike an entirely different EEC)
-Thomas
Thomas is offline
