Temp Problem. - TCCoA Forums
post #1 of 5 (permalink) Old 03-01-2004, 07:32 PM Thread Starter
CamellionCat's Avatar
Send a message via AIM to CamellionCat
Temp Problem.
ok here it goes, it dosent look like its a head gasket situation, since they are brand new. When i turn on my car in the morning i will drive it for like 2 mins then the gauge will climb up to the middle on NORM which is a good normal temp but then it will move back down to the N what is this trapped air???? and how can i get it out????? by the way i have no coolant in oil, i have no water leaks and i have no white smoke coming out my exhaust. thanks for the help.
CamellionCat
95- Cougar- SOLD (in loving memory)
Mods-17x9 cobra r's,H&R springs,KYB shocks & struts,removed air silencer,9"K&N cone,gutted cats,dual glasspack setup,cooling fan switch, B&M 24,000 tranny cooler.
Back in the game!!!
97 Lincoln Mark VIII LSC-opal opalescent with black interior, upgraded with a 98 tranny, 18x9 black saleen speedstars, LMS dual tip mufflers, 5% tints all around.
CamellionCat is offline
post #2 of 5 (permalink) Old 03-01-2004, 09:16 PM
Sticky t-stat? It has happened on every vehicle that I've driven except my work truck which is an 02. I think its probably normal.
93SC is offline
post #3 of 5 (permalink) Old 03-01-2004, 09:20 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
yeah try a new t-stat and bleed the coolant system. When you replace the t-stat start the car, and fill the radiator until it bubbles over a bit.
-Thomas
Thomas is offline
post #4 of 5 (permalink) Old 03-01-2004, 11:32 PM Thread Starter
how do i bleed the cooling system?
CamellionCat
Back in the game!!!
post #5 of 5 (permalink) Old 03-02-2004, 12:00 AM
There is a sticky at the top of this forum.
93SC is offline
