Big Engine Problem - TCCoA Forums
post #1 of 18 (permalink) Old 03-04-2004, 07:44 PM Thread Starter
Angry Big Engine Problem
what's wrong with an engine if it sounds like i got a damn snare drummer in my engine and it overheats severely
92ILTBird is offline
post #2 of 18 (permalink) Old 03-04-2004, 08:36 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
Could you try and go into more details about how the engine is acting? Sounding like a snare drum doesn't exactly explain a lot ya know?
Sounds like maybe you're pinging. What octane do you run? As for the overheating. can you go into more detail about how it overheats? Does it gradually climb up to hot or just it skyrocket out of nowhere? And how hot does it get?
-Thomas
Thomas is offline
post #3 of 18 (permalink) Old 03-04-2004, 09:34 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
<---drummer
what kind of snare drum does it sound like? piccolo, marching, or what? is the drummer doing a drumroll, flam taps, or sixteenth notes? jk, i had to do it
as for the overheating, you better get that fixed now. dont drive the car if its overheating or your headgaskets will go bye bye like mine yesterday
2014 GT
1990 300ZX TT
big mike is offline
post #4 of 18 (permalink) Old 03-04-2004, 10:13 PM
Uber Luber
Thomas's Avatar
Originally posted by big mike
<---drummer
DITTO. ya weirdo.
Hey yeah mike's right. do NOT drive a car that overheats. if the head gaskets are blown already you're just asking for it by driving the car like that.
When was the last time you replaced the thermostat?
-Thomas
Thomas is offline
post #5 of 18 (permalink) Old 03-05-2004, 03:57 PM Thread Starter
when i try to start it it turns over really slow and the overheating is ilke all at once
when i slow down and come to a stop the whole car shuts down
post #6 of 18 (permalink) Old 03-05-2004, 08:54 PM
Do you hear any loud hissing sounds?
Any unusual smoke coming out of it?
Also check your oil, does it smell weird, is it black or burnt?
KewlBird is offline
post #7 of 18 (permalink) Old 03-05-2004, 09:19 PM
TBird232ci's Avatar
Send a message via AIM to TBird232ci
TBird232ci is offline
post #8 of 18 (permalink) Old 03-05-2004, 11:19 PM
Uber Luber
Thomas's Avatar
Originally posted by TBird232ci
sounds as if its working on locking up
I agree, you probably have a very large leak going into the cylinders. That'd be my guess. I've seen a locking up issue with a grand am that had blown HG's and it was leaking into the cylinders bad.
-Thomas
Thomas is offline
post #9 of 18 (permalink) Old 03-05-2004, 11:57 PM
sounds like you got a bad headgasket leak and the snare drum noise could possibly be rod knock from a bent rod
billabong132132 is offline
post #10 of 18 (permalink) Old 03-06-2004, 08:25 AM
TBird232ci's Avatar
actually, if the headgasket issue has gotten that bad, the coolant WILL be mixed with the oil, and that will kill your bearings in short order, so that snare drum sound you have could be some nice rod knock, and it not wanting to turn over...that could be your dead bearings
post #11 of 18 (permalink) Old 03-06-2004, 04:20 PM Thread Starter
well the oil was pretty black, and the knock very loud
post #12 of 18 (permalink) Old 03-06-2004, 04:51 PM
take your plugs out and look into your cylinders, if one piston is bright and shiny while the others are black, then you got antifreeze in there. Then it probably raised the compression through the roof and damaged a rod hence the knock. Partially hydrolocked would also cause it to be hard to turn over.
How's you oil pressure?
The antifreeze may have killed your bearings and now you have low pressure which is causing some knocking.
But if the knock is very loud as you say I would bet on Rod knock.
post #13 of 18 (permalink) Old 03-06-2004, 08:19 PM Thread Starter
well...anybody wanna buy a car
post #14 of 18 (permalink) Old 03-06-2004, 08:24 PM
Red face
Sorry to laugh man, but I pictured you saying that like fvck it who wants a car.
Yeah sounds like your engine is toast. Maybe you could try to find a 4.2 out of a 2002 f-150 or something for cheap and slap it in.
post #15 of 18 (permalink) Old 03-06-2004, 08:38 PM Thread Starter
yea, i'd really like to have a new car, but with no job at 16 years old and now no transportation, thats probably not gonna happen too soon
post #16 of 18 (permalink) Old 03-06-2004, 10:46 PM
There is an Illinois chapter, maybe some locals will help check out your bird.
post #17 of 18 (permalink) Old 03-09-2004, 08:18 PM
Hey, don't worry too much, even if the head gaskets are toast. If the car is basically a beater, why not get a cheap junkyard engine? Check the major internals, and if it looks ok, make a swap. Or look around this forum for a used engine. And you could probably find someone in IL who can help you out.
Steve
S_Mazza is offline
post #18 of 18 (permalink) Old 03-09-2004, 08:23 PM
Uber Luber
Thomas's Avatar
knappy will be taking out the 3.8 motor in his mustang to swap in his modded 3.8 from his wrecked bird. You could probably buy his old motor from the stang, he lives in Danville, IL.
http://www.cardomain.com/id/knappy
Thomas is offline
