Replacing Engine - TCCoA Forums
post #1 of 10 (permalink) Old 03-06-2004, 10:08 PM Thread Starter
bowez's Avatar
Replacing Engine
Not sure which would be better place for question, but for sake of double threads I'll just post the link.
http://forums.tccoa.com/showthread.p...threadid=36052
bowez is offline
post #2 of 10 (permalink) Old 03-07-2004, 06:11 AM
The SPI engine will drop in but a few things need to be modified. You'll need to get a modified fuel rail seeing the 99+ Mustang is returnless system and a few sensors need to be moved around and wiring needs to be rerouted and spliced. A few people here have done it, PJ, racecougar, Splitportbird to name a few. Do a search to see what's involved. Check out V6 Power also. To get it done quickly, you might be better off with the same style engine though, seeing it's the daily driver.
post #3 of 10 (permalink) Old 03-07-2004, 07:56 AM Thread Starter
bowez's Avatar
So we don't have the returnless lines?
bowez is offline
post #4 of 10 (permalink) Old 03-07-2004, 08:05 AM
Nope, I sent you a PM.
post #5 of 10 (permalink) Old 03-07-2004, 08:09 AM Thread Starter
bowez's Avatar
Oops
So then 98 be as far as I should go then, cause money and time big issues.
bowez is offline
post #6 of 10 (permalink) Old 03-07-2004, 08:22 AM
Originally posted by bowez
Oops
Exactly! Good luck!
post #7 of 10 (permalink) Old 03-07-2004, 12:35 PM Thread Starter
bowez's Avatar
Well started with the basic diagonise; Coolant clean and green, Oil very dark but didn't see any sparklies when it drain out (another way to see if metal in it?), can manaul turn the crank (so its no seized right?).
bowez is offline
post #8 of 10 (permalink) Old 03-07-2004, 12:40 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
I'd just try and find a 96-98 3.8 with low miles and throw that in. MUCH easier to do because it's just a drop in and go type of thing, unlike the 99+ engines.
-Thomas
Thomas is offline
post #9 of 10 (permalink) Old 03-07-2004, 03:28 PM Thread Starter
bowez's Avatar
Well we have sparkles(gold) in the filter.
bowez is offline
post #10 of 10 (permalink) Old 03-07-2004, 07:37 PM Thread Starter
bowez's Avatar
Got talking to a mechanic buddy of mine, said I need to check the pan and see whats in there (to determine if rebuild is possible), he seems to think I dropped a piston and burned a bearing. If clyinder scored we replace if not proably rebuild (least the way he sounded).
bowez is offline
