Anyone Know Where Coolant Temperature Switch Is Located??? - TCCoA Forums
post #1 of 5 (permalink) Old 10-04-2002, 05:15 PM Thread Starter
I need to know where the coolant temperature switch is located...(Not the temperature sending unit).
Anyone Know?
Beirutsfinest
Edit:
BeirutsFinest is offline
post #2 of 5 (permalink) Old 10-05-2002, 01:07 AM Thread Starter
JT
JT...You are the man...thanks alot for the location of that switch.....I think you have just solved my temp problem...along with Marvin M's and about 10 other guys on this site...Thanks JT...such a clear and accurate picture.
BeirutsFinest
post #3 of 5 (permalink) Old 10-05-2002, 04:12 PM
CamellionCat's Avatar
Send a message via AIM to CamellionCat
Hey beirutsfinest.
hey i think i have replaced that sensor also, do i need to replace the ecc sensor or the switch that engages on top of the sensor?????
Marvin M.
95- Cougar- SOLD (in loving memory)
Mods-17x9 cobra r's,H&R springs,KYB shocks & struts,removed air silencer,9"K&N cone,gutted cats,dual glasspack setup,cooling fan switch, B&M 24,000 tranny cooler.
Back in the game!!!
97 Lincoln Mark VIII LSC-opal opalescent with black interior, upgraded with a 98 tranny, 18x9 black saleen speedstars, LMS dual tip mufflers, 5% tints all around.
CamellionCat is offline
post #4 of 5 (permalink) Old 10-06-2002, 01:20 AM Thread Starter
Marvin
Marvin....
You need to replace the sensor itself (not the plastic piece on top....The sensor itself is referred to as a sensor or a switch....If you look at the sensor when you take it off...you will see that there are 2 metal rods coming out of the sensor on the top side of it..This is where the wires connect to it.
I will replace mine tomorrow (Sunday)...I'll let you know what happens, BTW..the sensor cost me $32.00
BeirutsFinest
post #5 of 5 (permalink) Old 10-07-2002, 06:59 PM
Beirutsfinest.........
dude i have replaced my ecc temperature sensor and quess what..... problem solved ill let you know how it turns out tommorrow when i drive my cougie to work.
peace out.
Marivn M.
Back in the game!!!
