SC headers on a NA 3.8 - TCCoA Forums
post #1 of 13 (permalink) Old 10-05-2002, 02:14 AM Thread Starter
What will this do for me? will it give me any gains and will they bolt up without modification?
Matt
Crymson Thunder is offline
post #2 of 13 (permalink) Old 10-05-2002, 10:06 AM
jim
no headers on SC's...pretty much the same as n/a exhaust manifolds...96/97 3.8's came with factory headers...i upgraded to these on my 94
jim is offline
post #3 of 13 (permalink) Old 10-05-2002, 07:52 PM
Re: SC headers on a NA 3.8
Matt
Jim is right, SC's didn't come with headers, they came with exhaust manifolds, and they are the same as the n/a v6's.
If you meant aftermarket headers for SC, then it's a different story.
KewlBird is offline
post #4 of 13 (permalink) Old 10-06-2002, 02:58 PM
what kinda performance did you get out'a the 96/97 headers as opposed to ours...
Spike is offline
post #5 of 13 (permalink) Old 10-06-2002, 05:34 PM
jim
more
jim is offline
post #6 of 13 (permalink) Old 10-07-2002, 04:29 PM
wow, thanks a lot....
Spike is offline
post #7 of 13 (permalink) Old 10-07-2002, 07:27 PM
jim
i felt a noticeable gain through out the rpm band...even low end torque improved a bit...long tubes could only be better...99+ longtubes may work but then a new y pipe must be made of course...ford rated them at an extra 5 hp...i'm sure i gained at least that
jim is offline
post #8 of 13 (permalink) Old 10-07-2002, 07:43 PM
hehe there we go, thanks man
Spike is offline
post #9 of 13 (permalink) Old 10-13-2002, 12:48 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
i've been thinking about getting the 96/97 shortys too. I'll also need the driver side down tube and egr tube correct? I was also thinking of modding my exhaust, I already have dual exhaust with no mufflers just the res. but I was thinking replacing the res with a cat and having tubes where my cats are now, eliminating that horrible 90o bend on the driver side, then putting glass packs on the dual tips. what do you think that will do for me? 1 cat, shorty headers, and 2 glass packs. I'm kinda getting the exhaust ready to be good for the 4.3 I will be putting in sometime.
-Thomas
Thomas is offline
post #10 of 13 (permalink) Old 11-12-2002, 05:33 PM
Send a message via AIM to Bacondoggy
go for the stock mustang v6 headers - they are alot nicer and flow more - have bigger collectors and aren't cast iron. only problem is the collectors are at a different angle so your other exhaust would need to be reworked (I would just get some downpipes made)
Bacondoggy is offline
post #11 of 13 (permalink) Old 11-12-2002, 06:24 PM
stock mustang from what years?
Spike is offline
post #12 of 13 (permalink) Old 11-12-2002, 06:25 PM
jim
the 96/97 mn12 3.8 headers are the same thing...except they fit
jim is offline
post #13 of 13 (permalink) Old 11-12-2002, 06:44 PM
lol well then stock 96/97 bird headers are the way to go.... so, any of you guys think i can get too 200 ponies at the crank? with what i have done then reinhart automotive chip and j-mod... then after that i thinkin the headers...
Spike is offline
