Ended up in a ditch, now my car it idles strange - TCCoA Forums
post #1 of 14 (permalink) Old 11-27-2004, 02:38 PM Thread Starter
Birdman232's Avatar
Wednesday night i was drifting down a twisty road and I went too far and the open diff. caught and i went the wrong way and slammed into a ditch and centered out. I had a friend pull me out. Now After a day or two the car idles kind of strange, it will idle at around 800rpm then jump up to 1200 and come back down to 800. It does this the entire time the car is in P and idling. It will also do the same in D. Ive reset the computer, and had it checked for codes, and its still all the same idling. Ive also Carefully cleaned the MAF and cleaned out the Throttlebody a week or so before.
BTW, nothing is messed up under the car, or bent/broken anywhere. So maybe its just a concidence but i'm not sure.
Any suggestions?
Birdman232 is offline
post #2 of 14 (permalink) Old 11-27-2004, 06:04 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
take the iac off and clean it out, if that doesnt work, the IAC itself may be bad. That'd be my best guess for you.
-Thomas
Thomas is offline
post #3 of 14 (permalink) Old 11-27-2004, 07:07 PM Thread Starter
Birdman232's Avatar
-Thomas
I was thinking that from what ive read on the forums, but I'm not 100% sure what it is. Is it the little canister looking thing on the top of my TB thats held on with two bolts and has a little rubber gasket under it?
EDIT: heres a pic of what I'm talking about
post #4 of 14 (permalink) Old 11-27-2004, 11:44 PM
Resident Line Creator
th3subtl3on3's Avatar
Yes that is your IAC.
-Brian
th3subtl3on3 is offline
post #5 of 14 (permalink) Old 11-27-2004, 11:52 PM
Uber Luber
Thomas's Avatar
and the gasket is paper
Thomas is offline
post #6 of 14 (permalink) Old 11-28-2004, 09:59 AM
Geez, and I thought my engine bay was clean
I am on the bandwagon of needing to clean my IAC...
sc0tty8 is offline
post #7 of 14 (permalink) Old 11-28-2004, 11:19 AM Thread Starter
Birdman232's Avatar
meh, rubber, paper, both come from a tree..
Thanks guys, I'll try cleaning it out this afternoon, hopefully it helps.
post #8 of 14 (permalink) Old 11-28-2004, 12:05 PM
Your car ended up in a ditch and it looks 10x cleaner than mine.
mastarecoil is offline
post #9 of 14 (permalink) Old 11-28-2004, 02:06 PM Thread Starter
Birdman232's Avatar
the outside of the car is all covered in mud and dirt, and the interrior needs cleaned up and finished(rear seat delete and carpet the sub box) the only thing thats clean in teh car is the engine/engine bay
its hard to believe that engine has 106k miles on it and its still running stong and its that clean. but it helps stay clean because I have a pressure washer here so i can clean it while the engine is cool so i dont warp anything. I do this about 1-2 times a month when i clean my car.
post #10 of 14 (permalink) Old 11-28-2004, 08:20 PM Thread Starter
Birdman232's Avatar
well, that did it, I cleaned out the IAC, then the TB and MAF once more, reset the computer and its running great now.
post #11 of 14 (permalink) Old 11-28-2004, 09:48 PM
Uber Luber
Thomas's Avatar
glad to hear it. Also, seeing as how you powerwash your car pretty often, make sure you cover all the elctrical with plastic sacks and duct tape if you don't already.
-Thomas
Thomas is offline
post #12 of 14 (permalink) Old 11-28-2004, 09:58 PM
jk69cat's Avatar
check the motor mounts and plug wires and make sure you didnt pinch any wires either . i had been forced off the road with my 1990 3.8 cougar and i did the smae thing , but smacked the subframe when it went off the road it ripped the lh mount in two . and cut 3 of the plug wires .
mn12 less!
jk69cat is offline
post #13 of 14 (permalink) Old 11-28-2004, 09:59 PM
Uber Luber
Thomas's Avatar
he fixed it
Thomas is offline
post #14 of 14 (permalink) Old 11-29-2004, 02:57 AM
Drifting Thunder's Avatar
Send a message via AIM to Drifting Thunder Send a message via Skype™ to Drifting Thunder
...and the open diff. caught and i went the wrong way...
That's what I'm always talking about. Drifting an open diff car, in my opinion, isn't even safe.
-Andy
'94 Thunderbird SC 5-speed
Drifting Thunder is offline
