Spring Question - TCCoA Forums
post #1 of 6 (permalink) Old 12-03-2004, 04:26 PM Thread Starter
Spring Question
I know, not the correct place for this, but this is where the 3.8 experts are.
I am doing a suspension rebuild and want to swap out the sprigs. The old ones are sagging.
Can I run a set of SC springs and still stay at stock height (I Don't want a drop)? Will the front end of the car be to raised?
Anyone do this?
Thanks!
Jim
1993 LX 5.0
JSGAuto is offline
post #2 of 6 (permalink) Old 12-03-2004, 07:23 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
man, sc springs raise a 4.6 car 1" You'll be sitting about 2" higher than stock.
-Thomas
Thomas is offline
post #3 of 6 (permalink) Old 12-03-2004, 09:02 PM Thread Starter
hmmm.
I have seen SC springs on 4.6 cars before, side by side. No height change. They are the same as sport springs...
Anyone try this on a 3.8?
THanks for the reply!
Jim
1993 LX 5.0
JSGAuto is offline
post #4 of 6 (permalink) Old 12-03-2004, 11:20 PM
Uber Luber
Thomas's Avatar
Originally posted by JSGAuto
hmmm.
Jim
Ah, after some research it would appear you are right. I had seen weswing with his tbird that had swapped to SC springs and it sat quite high, but maybe something was binding in his supension...?
-Thomas
Thomas is offline
post #5 of 6 (permalink) Old 12-04-2004, 06:22 AM Thread Starter
Yea that is a bit taller. It could also be the tire/rim combo. Maybe it is shorter then stock? Or maybe he shead a few pounds off the car.
Joust guessing.
1993 LX 5.0
JSGAuto is offline
post #6 of 6 (permalink) Old 12-05-2004, 10:27 PM
I was running SC springs on the rear of my 94 for a while. They definitely raised the car at least 1".
-Rod
