removing serpentine belt - TCCoA Forums
post #1 of 4 (permalink) Old 10-07-2002, 04:08 PM Thread Starter
How do I remove the belt on an '89 Cougar with a 3.8??
grooves12 is offline
post #2 of 4 (permalink) Old 10-07-2002, 04:36 PM
1-Put a wrench on the tensioner. It is on the passenger side of the engine under the AC compressor.
2- Pull up.
3-The tensioner should release its preasure. You may need a big wrench, mine was on tight!
4-Wile holding up the tensioner with the wrench, use your free hand to work the belt off the pulley.
5-Now it has no tension and you can remove it.
Jim
1993 LX 5.0
JSGAuto is offline
post #3 of 4 (permalink) Old 10-08-2002, 07:39 PM
JSGAuto,
I would love to know how your P&P goes, and what results you get, I think that this is the next thing I do. (Got a leaky Valve cover to get in there for anyway)
buggzz is offline
post #4 of 4 (permalink) Old 10-09-2002, 04:33 PM
Sure. I am going to set a basline with my car on the 1/4. Then I will swap on the new intakes and see what happons. My best advice would be to get an extra set of intakes from a junkyard. P&P is very time consuming. It isn't somthing you can get done in a weekend.
I have been taking longer then I wanted with these since I got the SC and I broke my dremal . But hopefuly it will be done soon.
Jim
1993 LX 5.0
JSGAuto is offline
