In the middle of HG replacement and need help - TCCoA Forums
post #1 of 9 (permalink) Old 12-13-2004, 10:19 PM Thread Starter
Well i got the driver side head off with only minor frustration.
The problem I am having is with the passenger side. I can't get the exhaust manifold bolts off where they connect to the cats. They are extremely rusted and will not budge and are starting to round off. Any suggestions are much appreciated.
silversin is offline
post #2 of 9 (permalink) Old 12-14-2004, 01:14 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
mini torch, and THIS STUFF
The PB B'Laster is God's gift to frustrated mechanics. The stuff works like magic man, most auto parts and hardware stores should carry it.
First, take a mini propane torch and ehat the bolts up. There are two parts to the flame of a propane torch, the outter light blue, and the inner dark blue. The hottest point of the flame is at the very tip of the inner blue flame. Keep the tip of that on the stud (not the manifold or nut) until it's really freakin hot. I'd say about 5 minutes or so. Then spray B'Laster on it. As the lubricant cools the stud, the metals will expand and contract and the lubricant will get between the threads of the nut and stud. Let it sit for a while, then try twisting it off.
-Thomas
Thomas is offline
post #3 of 9 (permalink) Old 12-14-2004, 07:19 PM
Or just break them like a man!!
And then you get to learn how to use a tap and die!
brokenmachines_e2 is offline
post #4 of 9 (permalink) Old 01-05-2005, 09:59 PM
I broke one bolt off with a breaker bar( and took off alot of skin on my right hand) and cut the other one off with a cut off wheel. I absolutely cannot get the drivers side bolt off. the one you can get too came right off, but I cannot get to the other one to even think about cutting it off. If I could get the heat shield off the cat I may have a better chance at it. I'm gunna cut them off tomorrow.
mlbuxbaum is offline
post #5 of 9 (permalink) Old 01-06-2005, 08:38 AM
Yeah, I took the heatshield off of my cats. I probably should put them on.
post #6 of 9 (permalink) Old 01-06-2005, 08:51 AM
couldn't get the heat sheild off, so I cut the one bolt off on the cat. 2 minutes....done.....heads on....torqued down....intake on......getting there.
post #7 of 9 (permalink) Old 02-09-2005, 02:18 AM
hell i am thinking about cuting my cats off and just haven str8 pipes wonder how that will sound with my 2.25 duals
lowthunder is offline
post #8 of 9 (permalink) Old 02-09-2005, 02:40 PM
bowez's Avatar
18" breaker bar & 4# hammer
or
Cut off wheel
When I replaced my engine I used some stuff thats better than PB but is only locally aviable and was able to remove them with only a combonation wrench.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #9 of 9 (permalink) Old 02-15-2005, 12:23 AM
MaleWhore
smokymance's Avatar
i never removed the headers from the exhaust when i got the heads off...u could try that way
smokymance is offline
