3.8 supercharger - TCCoA Forums
post #1 of 12 (permalink) Old 12-15-2004, 10:45 AM Thread Starter
mechman1984's Avatar
3.8 supercharger
Hey
Does anybody know how many cfm a supercoupe blower will flow. Thanks.
Will
Will
08 Ford Ranger
95 Thunderbird V8-Sold!
mechman1984 is offline
post #2 of 12 (permalink) Old 12-15-2004, 03:12 PM
AEDM8's Avatar
http://www.automotive.eaton.com/prod...argers/M90.asp
Hope that answers your question.
AEDM8 is offline
post #3 of 12 (permalink) Old 12-15-2004, 07:37 PM Thread Starter
That works great thanks.
Will
Will
08 Ford Ranger
post #4 of 12 (permalink) Old 12-16-2004, 03:26 AM
Dim Bulb
Falcon5783's Avatar
interesting, the M90 only adds 44 hp at 10 psi and 12k rpm. I always thought it was more than that.
+1
Elliot
Falcon5783 is offline
post #5 of 12 (permalink) Old 12-16-2004, 03:27 PM
AEDM8's Avatar
There is too much heat generated at that RPM to make much power.
AEDM8 is offline
post #6 of 12 (permalink) Old 12-16-2004, 05:29 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
yeah, I doubt those tests include the stock intercooler on the SC, although the stock intercooler may not be very efficient, it helps a lot with the heat monster M90.
-Thomas
Thomas is offline
post #7 of 12 (permalink) Old 12-16-2004, 05:37 PM
AEDM8's Avatar
Not all things Eaton revolve around the supercoupe Thomas.
Those tests are showing the M90's abilities without aid.
AEDM8 is offline
post #8 of 12 (permalink) Old 12-16-2004, 05:52 PM
Uber Luber
Thomas's Avatar
my point exactly The intercooler obviously helps out because a supercoupe makes 70-80hp more than the NA v6.
Thomas is offline
post #9 of 12 (permalink) Old 12-16-2004, 05:53 PM
AEDM8's Avatar
So we agreed on this....
No help me with my TB problem.
AEDM8 is offline
post #10 of 12 (permalink) Old 12-17-2004, 04:46 AM
Dim Bulb
Falcon5783's Avatar
How difficult is it to add the M90 to the 3.8 NA? I understand it's all pretty much just bolt ons, but do the NA and SC have the same heads/compression ratios?
+1
Elliot
post #11 of 12 (permalink) Old 12-17-2004, 01:03 PM
Uber Luber
Thomas's Avatar
the 3.8 has a 9:1 CR, the SC has 8.25:1, which allows for more boost. The SC also has a knock sensor which retards timing in the event that it starts detonating.
Thomas is offline
post #12 of 12 (permalink) Old 12-17-2004, 10:03 PM
AEDM8's Avatar
Man, you 3.8 guys get hit with that question every 5 minutes dont you. Its crazy how often people want information on that.
Someone should make a sticky about it.
AEDM8 is offline
