What after cam swap? - TCCoA Forums
post #1 of 3 (permalink) Old 01-08-2005, 01:37 PM Thread Starter
Send a message via AIM to FasTBird232 Send a message via MSN to FasTBird232 Send a message via Skype™ to FasTBird232
I'm sure some of you saw the piece in last month's Hot Rod about a Comp Cams making camshafts for the 3.8/4.2. My question is, what do you have to do after the swap, electronic wise or otherwise?
FasTBird232 is offline
post #2 of 3 (permalink) Old 01-08-2005, 03:52 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
you can just throw it in and run it that way, but it would be best to get a dyno tune to get the most power out of it, and even out the air/fuel ratio since the cam will change it. But if its just a mild cam you can get away with not getting it tuned and still be good.
Comp Cams are not the only cams for the 3.8 I hope you know. Check out:
www.rpm-mustangs.com
www.moranav6racing.com
www.supersixmotorsports.com
-Thomas
Thomas is offline
post #3 of 3 (permalink) Old 01-08-2005, 04:08 PM
Uber Luber
Thomas's Avatar
"So the computer will change the air/fuel ratio itself?"
to a certain point, but a dyno tune with a performance chip that finely tunes the air/fuel would be best.
Thomas is offline
