3.8 head gasket INSTALL - TCCoA Forums
post #1 of 5 (permalink) Old 01-09-2005, 11:09 AM Thread Starter
hey guys im in the midst of changing my headgaskets, ive actually got the heads off and at the shop but i will be picking them up tomm. ive got sorta a mess, ive got most all plugs and hoses labeled, but on the wiring harness, i just ended up clicking and up plugging until it came out completely, i know which plugs go where due to labels, but i dont have ANY idea how it was routed
also
http://www.pickproparts.com/pictures...num=HS8857PT5%
those 2 bags of gaskets in that picture, the only ones in little bags....
i never saw those, what are they and where do they go, some injector stuff or something
if anyone has pictures of the job or any steps of it that would be helpful
its always easier to tear down than put back togather
rolledthatho is offline
post #2 of 5 (permalink) Old 01-09-2005, 01:48 PM
The bag nearest the top of the picture has new o-rings for your fuel injectors. The bag just below it has new valve seals.
-Rod
post #3 of 5 (permalink) Old 01-09-2005, 01:52 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
injector o-rings on top, valve seals on the bottom. do you have a haynes manual?
2014 GT
1990 300ZX TT
big mike is offline
post #4 of 5 (permalink) Old 01-09-2005, 11:43 PM Thread Starter
yup i have a haynes manual but i havent opened it yet...
i guess i need to do that tomm when i pick up the heads
thanks fellas
post #5 of 5 (permalink) Old 01-10-2005, 08:39 AM
Your wiring harness should be laying closest to the components it connects to.
Just make sure it stays out of the way of any moving parts, and youll be fine. Zip ties are a god-send.
brokenmachines_e2 is offline
