shop in houston???help? - TCCoA Forums
post #1 of 14 (permalink) Old 01-17-2005, 06:21 PM Thread Starter
The Stevinator's Avatar
So,
I was going to install a new ported upper intake manifold, fuel injectors 14lb., and a 56mm throttle body on my 94 t-bird (unsupercharged). I ended up getting sent the wrong man., and had a hell of a time getting things back on. So, I ended up putting the old one back on with the new injectors and throttle body. I believe I have everything set up right, but now the car shakes violently when i drive it, and I can't get any decent acelleration out of it all. I checked everything, but can't find a problem.
does anyone have a shop or know somebody in town that can help mee???? I am a poor college student and need helppp!!!!
The Stevinator is offline
post #2 of 14 (permalink) Old 01-17-2005, 06:35 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
did you reconnect the PCV tube that plugs in underneath the manifold? I forgot that my first time doing the manifolds and took me a while to figure it out.
Otherwise, there's bigmike He's done the intake manifolds a few times now.
-Thomas
Thomas is offline
post #3 of 14 (permalink) Old 01-17-2005, 06:41 PM Thread Starter
yeah i did that, and triple checked everything. however, on the vacum hoses, green goes into the egr valve assembly, and the red goes into the manifold, and the larger on on top of that goes into the regulator.
i think i may try taking off the new throttle body, and put on the old one. maybe see if that does anything. im just totally running out of ideas here. it also threw up some codes on the way to work this morning. so i gotta check those out too. if anyone in houston has a shop though i would be in their debt to help me.
post #4 of 14 (permalink) Old 01-17-2005, 06:51 PM
Uber Luber
Thomas's Avatar
did you install the TPS correctly on your new throttle body?
Thomas is offline
post #5 of 14 (permalink) Old 01-17-2005, 06:58 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
dont go to a shop, dude. they will charge you out the wazoo for labor. i would help you out, but im 500+ miles from houston now.
2014 GT
1990 300ZX TT
big mike is offline
post #6 of 14 (permalink) Old 01-17-2005, 06:59 PM Thread Starter
yeah i installed it facing the passenger side with no tension. should i move it forward a revolution and have tension on it before i screw it into the tb?
post #7 of 14 (permalink) Old 01-17-2005, 09:34 PM
Make sure you put the plug wires on right for starters
mazda6 Sport- 06
100hp worth of Stickers coming soon
Blake-vortech is offline
post #8 of 14 (permalink) Old 01-17-2005, 09:37 PM
Uber Luber
Thomas's Avatar
I know mike already explained it to you privately, but just for future searches and things, you put the TPS on the throttle body 90* clockwise from the bolting position, then twist it to the bolting position and install the bolts. For best results, put a voltmeter on the ground and lead wire and twist it until it's between .96-.99v closed. You'll want to have the key in the "on" position but not running while doing this.
-Thomas
Thomas is offline
post #9 of 14 (permalink) Old 01-17-2005, 09:49 PM
Uber Luber
Thomas's Avatar
there isnt even any reason to remove those on a v6 when taking off the upper manifold
Thomas is offline
post #10 of 14 (permalink) Old 01-17-2005, 10:24 PM Thread Starter
i replaced the throttle body
post #11 of 14 (permalink) Old 01-17-2005, 10:51 PM
Uber Luber
Thomas's Avatar
yeah but you'd also taken off the manifold too didnt you?
Anyways, you may have broken the TPS when you installed it incorrectly, so install it correctly and see if that makes a difference, if it doesn't, you'll need to get a new one.
-Thomas
Thomas is offline
post #12 of 14 (permalink) Old 01-17-2005, 11:00 PM Thread Starter
yeah, thats the conclusion mike and i came too. i went out and tried to do it right, and now the car doesnt start. well it starts, and dies right away. so i think thats it. hopefully that was like the total cause of my trouble. but we will see tommorow. i have to walk to autozone!!! sucks...
post #13 of 14 (permalink) Old 01-18-2005, 06:36 PM Thread Starter
so now im running rich, i replaced the throttle body back with the stock one, and got it running, however the exhaust is way too dark. and it is spraying a little gas out the exhaust. it sounds like it may be running rich on the passenger side. the driverside sounds like its trying to keep up. like put put put put put put put. any advice??
post #14 of 14 (permalink) Old 01-18-2005, 10:59 PM
Uber Luber
Thomas's Avatar
well that is very odd. Sounds like a stuck injector or fugged up eec.
Thomas is offline
