interesting find at work... - TCCoA Forums
post #1 of 5 (permalink) Old 01-26-2005, 06:41 AM Thread Starter
Johnny Bling Bling
93 lx's Avatar
as most of you know, i work in the parts dept of my local ford dealership. i was considering swapping in the 4.2 cam. what i found is that, according to ford part numbers, the 97-03 f150 4.2 cam and the 89-95 3.8 tbirds are the same. 96/97 cams are different. so, i guess, in thery, that i should not use a ford cam, and therefore probably get one from rpm-mustangs. any input, or contradictory info?
2009 Ford Flex Limited AWD
93 lx is offline
post #2 of 5 (permalink) Old 01-26-2005, 09:01 AM
The f150 cam should NOT be the same as any 3.8L unless ford decided the 4.2L cam would be a suitable replacement for the 3.8L cam. I personally would go with an RPM cam, they are fairly cheap.
rancherlee is offline
post #3 of 5 (permalink) Old 01-26-2005, 09:22 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
Thomas is offline
post #4 of 5 (permalink) Old 01-26-2005, 09:38 AM
Jedi Master
mn12xr7's Avatar
yeah the4.2 and 3.8 cams are the same, It had been discussed before, I do believe it was Thomas that brought up this point.
-Orlando
mn12xr7 is offline
post #5 of 5 (permalink) Old 01-26-2005, 09:46 AM
Uber Luber
Thomas's Avatar
no they are not the same, the 4.2 is better, I dont think it's anything in the lift, just the duration. But they are deffinetely not the same.
Thomas is offline
