ok got a new problem!!....HELP me AGAIN!..haha - TCCoA Forums
post #1 of 28 (permalink) Old 10-11-2002, 03:12 AM Thread Starter
ok this morning when i started my car up the idel was a little weird and then my check engine light came on for like 3 minutes maybe longer,,,,,anyways...ok now when i put my car in reverse it will shake real bad and my rpms drop real low so i tap the gas and it quits acting up for a few seconds.....but when i start driving my car and it starts to warm up it doesnt act up at all and the engine light goes off....what is causeing this problem?? to mee it seems like something to do with my temp sending unit or my coolant temp sensor???? you think???...im lost...it seem like when i start my car something is telling my compuer in my car that my car is already warmed up when its not cause it acts fine when my temp goes up and my temp gauges starts working????....im probably confusing you gusy but i dont really know how to word thjis stuff right sorry....but hopefully someone will be able to help!!
thanks guys
Jay
SOOP!!!! where are you!!!...haha
Louisville bird is offline
post #2 of 28 (permalink) Old 10-11-2002, 03:13 AM Thread Starter
also forgot to add..its a 91 3.8L non sc
incase you guys needed to know
Jay
post #3 of 28 (permalink) Old 10-11-2002, 07:05 AM
What the he11?? Again??
Sounds suspiciously similar to a problem that MO_XR7 is having in this thread .
Does that sound similar?
soop is offline
post #4 of 28 (permalink) Old 10-11-2002, 12:43 PM Thread Starter
yes sounds very similar!!....but i have already replaced my EGR and TPS...not to long ago....so imthinkin it has something to do with my temp sending unit or coolant temo sensor?? could these 2 thing cause my problems?...i dont really know what it is man....im sure you alreay know by now i am a complete dumb*** when it comes to the motor problems! HAHA
thanks
Jay
post #5 of 28 (permalink) Old 10-11-2002, 02:35 PM
Ok
First Thing, Do you have power brakes? How do your brakes feel when you step on them? If you have power brakes...you may have a vaccuum leak in your power brake booster....Check it out.
BeirutsFinest
BeirutsFinest is offline
post #6 of 28 (permalink) Old 10-11-2002, 09:07 PM
Since you seem to be having similar issues to MO_XR7, try the following thread discussion related to the DPFE. Read the whole thing.
DPFE thread.
Check it out.
soop is offline
post #7 of 28 (permalink) Old 10-11-2002, 09:49 PM Thread Starter
does my car have a DPFE???...if so where is it loctad at o my car.
91 3.8L
thanks
Jay
post #8 of 28 (permalink) Old 10-11-2002, 09:57 PM
It is part of your EGR system. In very brief terms, it provides added feedback on vacuum to the EEC. It's kind of a check on the EGR. I have one on my 92 and you should as well. The best description is in the thread. I'd just be repeating it in different words.
A more complex description is here . It contains a drawing which helps visualise what it does.
If I have a pic of it somewhere, I'll post for you.
soop is offline
post #9 of 28 (permalink) Old 10-11-2002, 10:01 PM Thread Starter
ok now what is a EVR solenoid???? and what does it do and where is it located??
thanks again
Jay
post #10 of 28 (permalink) Old 10-11-2002, 10:08 PM Thread Starter
so i will be able to see and get to this DPFE from the top of my car i wont have to get under it???.....
Jay
post #11 of 28 (permalink) Old 10-11-2002, 10:16 PM
I think that what was meant was EGR. Typo maybe?
Here's some pics straight from Haynes. Lovely book. I was just admiring my PFE today as a matter of fact.
Edit: Oops, yeah it is accessed from the top, close to the TB and EGR.
The EGR solenoid is on the firewall. When you are looking into the engine bay from the front, it is almost to the far left end of the firewall, further left than the PFE and has a small circular top. that's the best that I can describe. It has wires running from it to the wiring harness to the left of it. Does that help?
soop is offline
post #12 of 28 (permalink) Old 10-11-2002, 10:22 PM Thread Starter
yeah it helps a little bit man......so what is the difference between a EGR valve and a EGR solenoid????....and i know wwhat and where my EGR valve is.....now do you have a pic of the EGR solenoid???....sorry man im sure your hating me by now!
jay
post #13 of 28 (permalink) Old 10-11-2002, 10:37 PM
jay
Not a problem. It takes a command from the computer to regulate the vacuum flow in the EGR. With all this solenoid/valve/transducer/sensor bs, you can see how it can get a little confusing to diagnose. If you think about it all logically and how each component works together, then you can start to se how one thing failing can cause certain problem(s).
Sorry, the solenoid is kind of a vertical cylinder to the left on the firewall, maybe 6inches or so from the EGR. I can't actually measure it just now. Just have a check of the firewall.
soop is offline
post #14 of 28 (permalink) Old 10-12-2002, 12:34 AM
And quit teasin' that poor little import!
soop is offline
post #15 of 28 (permalink) Old 10-12-2002, 01:25 AM Thread Starter
HAHAHA
post #16 of 28 (permalink) Old 10-12-2002, 07:25 PM Thread Starter
well soop
i looked at my motor today and i checked out my PFE sensor...and it was melted on my EGR valve!!!...so i had a spare one from my old motor and i put it on and then my engine light just stayed on and nevr went off it use to just come on and go off every now and then.....so i went to auto zone and they ran my codes and i got code 327...which is my PFE sensor....so thats what i am gonna replace with a new one...so could my PFE be causeing all my problems....like i said in my first post on here??
thanks
JAY
post #17 of 28 (permalink) Old 10-12-2002, 09:01 PM
Appears that way, huh. Too bad no-one suggested that one earlier. Try picking up a used one. I know you're cheap.
Good luck and let us know if that was it. Remember to disconnect the neg battery cable when you replace it.
soop is offline
post #18 of 28 (permalink) Old 10-12-2002, 09:10 PM Thread Starter
yes i think everyone knows i am a cheap bast***!!!... haha but oh well whatever works man.
ill replace it and tell you guys what happens hope fully thats all i will have to replace.
thanks
Jay
post #19 of 28 (permalink) Old 10-12-2002, 09:11 PM Thread Starter
or maybe i should just buy a honda???? what you guys think???
HAHAHA just kidding!
Jay:p
post #20 of 28 (permalink) Old 10-12-2002, 09:16 PM
You appear to be attracted to them.
You've sure got a helluva strange shaped head and need some gym time too.
Edit: Actually pretty funny. You should put a big s**t-eating grin on him.
soop is offline
post #21 of 28 (permalink) Old 10-12-2002, 09:20 PM Thread Starter
post #22 of 28 (permalink) Old 10-12-2002, 09:40 PM Thread Starter
also soop
when i was checking out my car today i was looking for my DPFE sensor....and i couldnt see it....do i have to take off my throttle body/intake and EGR valve to see it??
thanks
Jay
post #23 of 28 (permalink) Old 10-12-2002, 09:48 PM
The DPFE is the same as the PFE, just with no D.
Is that what you are asking?
soop is offline
post #24 of 28 (permalink) Old 10-12-2002, 09:55 PM Thread Starter
you have mail
Jay
post #25 of 28 (permalink) Old 10-12-2002, 10:11 PM Thread Starter
ok ok ok soop
never mind man i feel like such a dumb***.....its just that my PFE looks different from that one that is in that other post you told me to read man sorry!!!....haha
thanks man...just hopefully when i replace it my car will be fine!
Jay
post #26 of 28 (permalink) Old 10-12-2002, 10:20 PM Thread Starter
im just confused cause my DPFE or PFE...whatever you call it....its a little gray square looking thing that has one plug and one vacuum line that comes out the bottom of it that connects to the pipe that screws/goes into the side of my EGR valve...
so why does my DPFE/PFE look different from the one in that other thread/post you told me to read??
thanks alot man
Jay
post #27 of 28 (permalink) Old 10-12-2002, 10:52 PM
thanks alot man
Jay
Ya got me, they could vary from year to year. Some may be balck, some grey. Mine is grey and is otherwise exactly the same as the pic in my post above.
soop is offline
post #28 of 28 (permalink) Old 10-12-2002, 10:59 PM Thread Starter
you have mail again
jay
