3.8 tech guys, hp estimate please - TCCoA Forums
post #1 of 9 (permalink) Old 02-09-2005, 12:42 AM Thread Starter
I drive a 95 automatic mustang 3.8L with 2.73 gears (bleh)
I'm going to have the following:
Mac CAI
56+mm BBK TB
25% UD pully
Ported upper/lower
Ported SC heads
RPM cam
manifold spacer
GT take-off exhaust
What kind of power should i expect at the wheels? Minimum, max?
jayls5 is offline
post #2 of 9 (permalink) Old 02-09-2005, 08:20 PM
Id spend your money on some gears first. They cost less than heads, and you will definitely be able to feel it in the old butt dyno.
brokenmachines_e2 is offline
post #3 of 9 (permalink) Old 02-09-2005, 09:12 PM Thread Starter
Yea but i pretty much have all of this stuff already. I either traded for it, or i'm parting it off my SC to put on my N/A 3.8 stang.
Not only that, but i like my highway gears for the time being.
jayls5 is offline
post #4 of 9 (permalink) Old 02-09-2005, 09:13 PM
SplitPortBird's Avatar
you have alot of variables there but I'll say 185-190HP
SplitPortBird is offline
post #5 of 9 (permalink) Old 02-09-2005, 09:18 PM
Moderator & Teksid Whore
guitar maestro's Avatar
i think you should also work a torque converter in there if you're gonna go with a higher RPM cam...it will make the take-off less sluggish and not have to up the gears too much
guitar maestro is offline
post #6 of 9 (permalink) Old 02-09-2005, 09:45 PM
I'll guess 160 - 170 at the wheels.
-Rod
post #7 of 9 (permalink) Old 02-12-2005, 08:46 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
rancherlee made 165rwhp properly tuned with:
UD pulley
base ported heads
207/215 (mild) cam
ported upper/lower intakes
60mm throttle body
I think that's about it. What kind of cam are you getting? Mik specs some awesome custom grinds, but his off-shelfers are great too. Are your heads just base ported? Is your ported upper intake base ported or is it cut&weld? Was there any intake runner length removed? If no runner length was removed you'll gain some torque with the spacer, probably around 5-7rwtq. With a cut&weld upper, ported lower, mild cam, ported heads, and UD pulley, with a good dyno tune and some timing worked in I think it could be capable of about 160-170rwhp
-Thomas
Thomas is offline
post #8 of 9 (permalink) Old 02-15-2005, 08:10 PM
MeanGene's Avatar
Have you thought about 1:8 roller rockers? Should be good for an easy 15 HP gain at the crank? Electric Fan 2-3 HP?
http://www.moranav6racing.com/rr.html
MeanGene is offline
post #9 of 9 (permalink) Old 02-15-2005, 08:14 PM
Originally Posted by MeanGene
Have you thought about 1:8 roller rockers? Should be good for an easy 20 HP gain at the crank?
try about 5-6hp, they add some lift and only 1-2* duration
rancherlee is offline
