Camshaft thrust spring - TCCoA Forums
post #1 of 7 (permalink) Old 03-01-2005, 03:08 PM Thread Starter
My manual speaks about thrust spring but it has no good pictures of it. There are only a drawing which doesn't macth with my Tbird's engine(1991 3.8 n/a). Can I handle camshaft's endplay with some spacer?
kaderyde is offline
post #2 of 7 (permalink) Old 03-01-2005, 04:50 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
i belive its referring to a thrust button and spring. the button is like a bolt, with the spring behind it, iirc. when i did my cam swap, i dont think there was a spring. i could be wrong. there is supposed to be a spacer behind the cam sprocket.
2014 GT
1990 300ZX TT
big mike is offline
post #3 of 7 (permalink) Old 03-02-2005, 10:19 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
there's no spring, are you sure you're looking at the 3.8?
There is the cam thrust bearing, maybe thats what its talking about. It slides on over the cam behind the keyway against the front journal, the keyway has to be removed to get it on or off. My reground cam didnt come with a thrust bearing and I didnt even notice, I installed the cam not knowing and the rotating assembly wouldnt turn over when I wrenched on the crank bolt, good thing my roommate glanced at my old cam and noticed it on there. That could have been catastrophic.
-Thomas
Thomas is offline
post #4 of 7 (permalink) Old 03-08-2005, 06:32 AM Thread Starter
Yes I'm sure 3.8. And my manual says "camshafts endplay is restrained by spring".
I tried first without cam thrust bearing(manual didn't say anything about it). After testdrive... and lot of repairing (heads) I noticed the thrust bearing on old cam...
Does anyone know the right torque for thurst button (bolt)?
kaderyde is offline
post #5 of 7 (permalink) Old 03-15-2005, 06:19 PM
I have this sound coming from under the hood of my car that sounds just like the "wheel of fortune". Anyway, I've been searching for solutions and read your post... could you tell me what it is before a mechanic takes a look at it?
XR7IST is offline
post #6 of 7 (permalink) Old 03-15-2005, 06:37 PM
Kentwood's Avatar
Send a message via AIM to Kentwood
I'm not familiar with the 3.8 cam thrust bearing, but alot of thrust bearings are also reffered to as wave springs.
Live in Louisiana? - Check out the LA Chapter forum!
http://forums.tccoa.com/forumdisplay.php?forumid=78
Kentwood is offline
post #7 of 7 (permalink) Old 03-15-2005, 11:25 PM
Uber Luber
Thomas's Avatar
loose rocker, bent pushrod, sticky lifter, spun rod bearing, worn rod bearing. There are many different things it could be. Can you tell where the noise is coming from on the engine?
-Thomas
Thomas is offline
