Help me with this code! - TCCoA Forums
post #1 of 3 (permalink) Old 03-03-2005, 09:39 PM Thread Starter
Aloha guys!
I'm not sure if this is the right place to post so if this is the wrong place, sorry......
Anyway, recently I done the TC upgrade along with 1-2 and 2-3 accum. upgrade. As I finished the project and went out to test drive, Service Engine light came on. When I check the code, it throw me code 327. Just waht is this code? As you can see, I have '94 3.8 T-bird.
I have a chilton service manual but it doesn't have my year T-bird code list. But if I look at the 91-92 3.8, it said PFE circuit below minimum voltage. What is PFE?
As always, thanks for all your help.
Toshi
94' Thunderbird LX - nice car!
3.8, wanna change to some kind of v-8 soon, wish had a Trac-loc, wish had set of 17inch, may settle with 16inch, wishing harder for true-dual. Wishing even harder for new paint job! Help!
my-first-bird is offline
post #2 of 3 (permalink) Old 03-03-2005, 09:48 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
327 - EGR valve position circuit below minimum voltage
Your EGR sensor may be bad. It's a little cube box on a bracket attached to a saucer like thing (EGR valve) right behind the throttle body.
-Thomas
Thomas is offline
post #3 of 3 (permalink) Old 03-05-2005, 12:53 AM Thread Starter
Thanks for the help!
I did replace the sensor and walah!! The code is gone.
Thanks!!
