water pump issue - TCCoA Forums
post #1 of 5 (permalink) Old 03-03-2005, 11:23 PM Thread Starter
water pump issue
i have a 96 t-bird 3.8 and i getting a loud sqeeking from under the the hood. i think it is possibly the water pump but not sure. the belt is 6 months old and just replaced alt. any help or suggestions will be welcome.
lscrews is offline
post #2 of 5 (permalink) Old 03-04-2005, 05:38 AM
Awaiting E-Mail Confirmation
tinman_72's Avatar
Try taking the belt off and turn the pump by hand. If it doesn't turn super-smoothly or if you can pull it in and out then it is time to replace it.
tinman_72 is offline
post #3 of 5 (permalink) Old 03-05-2005, 10:54 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
yeah and its a good idea to replace it while it's on its way out, because if it is indeed the waterpump making that noise, it may seize in a short time and you'll find yourself stranded on the side of a road with an overheated car
-Thomas
Thomas is offline
post #4 of 5 (permalink) Old 03-05-2005, 10:14 PM Thread Starter
Well i checked the water pump and it appears ok .. No play in it when I take the belt off and spins pretty smooth. its possibly just a slipping belt but i just changed it. Also can anyone tell me how to read the auto tensioner?
lscrews is offline
post #5 of 5 (permalink) Old 03-05-2005, 10:31 PM
if its truly a slipping belt, get some soap and run it across the back of the belt before re-installing.. it can help keep it quiet
brokenmachines_e2 is offline
