i have a leak! - TCCoA Forums
post #1 of 4 (permalink) Old 03-04-2005, 10:25 AM Thread Starter
i have a leak!
i have a leak....
it drips from the bottom corner passenger side of the radiator, the bottom corner about 3-4 inches in diameter is wet... and it drips, i cannot see where its comming from all i know is that its none of the hoses...and its leaking it drips fast like a drip every second or 2
surely its not a busted radiator is it?
also how can i get the fan shroud off, do i have to take the fan itself off to pull it up and out, if so which bolts hold on the fan?
thanks
rolledthatho is offline
post #2 of 4 (permalink) Old 03-04-2005, 02:21 PM
check the radiator pet-cock.
brokenmachines_e2 is offline
post #3 of 4 (permalink) Old 03-04-2005, 03:55 PM Thread Starter
wtf is that... and where is it, ill do a search as well
post #4 of 4 (permalink) Old 03-07-2005, 02:28 AM
It's the drain plug
amooset is offline
