Friggan O2 Sensors!!! - TCCoA Forums
post #1 of 11 (permalink) Old 03-07-2005, 07:13 PM Thread Starter
ok i guess the wire for the O2 sensor in front of the cat on the passenger side is longer than what the replacement ones i bought were. what brand O2 sensor can i get that is that same length. i got the Bosch one and it went in perfectly on the driver side but the passenger side was a *****. ASAP!
DeeDeeArrGuy is offline
post #2 of 11 (permalink) Old 03-08-2005, 12:14 AM
id just get some wire and splice as much as you need?
make sure its the same guage and all
rolledthatho is offline
post #3 of 11 (permalink) Old 03-08-2005, 02:06 AM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
get the bosch ones. when i replaced mine, i was worried that the wires wouldnt be long enough. but i got the replacement ones and they fit fine. you may need to tug on the connectors so they will reach.
2014 GT
1990 300ZX TT
big mike is offline
post #4 of 11 (permalink) Old 03-08-2005, 02:17 AM
Rob
Rob's Avatar
Send a message via AIM to Rob
It doesnt hurt anything to extend the wires if you really need more. Tape them up good to keep out water though. I put bosch on my '92 3.8 back in the day and had no problems.
-Rob
-Rob
Rob is offline
post #5 of 11 (permalink) Old 03-08-2005, 09:02 AM Thread Starter
is there a extension harness i can buy for them
post #6 of 11 (permalink) Old 03-08-2005, 09:33 AM
PCD
Confirmed V6 Nut
nope. You could try trading in the one you have for a universal fit Bosch O2 for your car. Then you splice the connector on to the wires. The universal fit O2 has longer wires.
PCD is offline
post #7 of 11 (permalink) Old 03-08-2005, 10:54 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
noooooo universal = bad. They operate at a wider range to comply with different computers on different cars, and this makes them less accurate. They make Bosch OEM fit ones with a long wire, I've seen it in the computer at work.
-Thomas
Thomas is offline
post #8 of 11 (permalink) Old 03-08-2005, 04:32 PM Thread Starter
so then how am i gonna find a replacement O2 sensor for the passenger side before the cat without having to do anything to the wires
post #9 of 11 (permalink) Old 03-08-2005, 04:52 PM
Motorboatin' SOB
big mike's Avatar
autozone, advance auto parts, o'reilly's, etc. the replacement ones are a direct swap, no cutting and splicing of wires needed. did you try tugging on the connectors some? i had to tug on mine some to make them "click" together.
2014 GT
1990 300ZX TT
big mike is offline
post #10 of 11 (permalink) Old 03-08-2005, 09:06 PM
Uber Luber
Thomas's Avatar
and like I said, my computer at work (o'reilly) listed 2 OEM replacements, one with a longer wire.
-Thomas
Thomas is offline
post #11 of 11 (permalink) Old 03-09-2005, 12:37 AM
man you can cut and splice for probably 2 dollars for a whole roll of the wire youd need...it will NEVER give you a problem because given enough slack nothing pulls on them they just lay there...
its a 3minute/ 2dollar fix
good luck figuring it out let us know what you come up with
