Loose Tapping - TCCoA Forums
post #1 of 8 (permalink) Old 03-10-2005, 10:38 PM Thread Starter
Loose Tapping
It sounds like woody woodpecker is under my hood on start up and during a light acceleration. Once i reach higher rpm it becomes quieter, returning as i back off the gas. Any ideas or solutions to this problem will be a great deal of help.
XR7IST is offline
post #2 of 8 (permalink) Old 03-10-2005, 10:43 PM
Send a message via Yahoo to goodguy
in the old days i'd say you have a sticky lifter or a bad rocker arm. Does it run a little rough at idle? May try a can of risoline oil additive. It will losen up sticky lifters and condition the seals around the valve stems.....and it don't cost but about ten bucks for a quart. Can't hurt anything...
goodguy is offline
post #3 of 8 (permalink) Old 03-10-2005, 11:25 PM
There is a pretty good chance that you have a spun rod bearing. Try listening to the engine with a long screwdriver, a piece of hose, or an automotive stethoscope (best tool to use) to pinpoint where the noise is coming from. If it is coming from low in the block, you probably have a spun bearing.
-Rod
post #4 of 8 (permalink) Old 03-10-2005, 11:30 PM Thread Starter
Okay, I added some seafoam but the only noticeable difference is engine performance. My only other choice before taking it to a mechanic seems to be a lighter oil. It could be that my oil is too heavy for the lifters (10w40) and aside from that, I'll check out more on a spun bearing.
Will it damage the engine longterm?
XR7IST is offline
post #5 of 8 (permalink) Old 03-10-2005, 11:34 PM
No, your oil is fine . I would take racecougars advice and see what you find. I'm sure he knows a fair amount about these cars. I'm still in the old school.
goodguy is offline
post #6 of 8 (permalink) Old 03-11-2005, 11:53 AM Thread Starter
Spun Bearing
Will a spun bearing damage the engine longterm?
XR7IST is offline
post #7 of 8 (permalink) Old 03-11-2005, 12:09 PM
I already sent you a PM describing the damage that a spun bearing can do to an engine.
-Rod
post #8 of 8 (permalink) Old 03-11-2005, 12:53 PM
bowez's Avatar
Yes a spun bearing will kill and engine.
My advice is, by going on what I percieve to be your knowledge level on cars, take it to a trusted mechanic and have them look at it. DO NOT tell them what you think it may be just have them listen. If they are a good shop they will just listen to that thing for free with you there and give you an opinion for nothing. Do not let them tell you, it needs to be put on the computer for I can almost garuntee it is not electiral.
Other option if you know someone that is good with cars to have a listen or get a recording an post it here.
In all honesty and kindness I think this is quickly getting beyond you.
I believe spun a bearing (never did find out 100%, sounded like a exhaust leak/rattle/knock) on my orginal motor and it lasted about 10-15 miles.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
