Iridium spark plugs - TCCoA Forums
post #1 of 15 (permalink) Old 03-18-2005, 08:18 PM Thread Starter
Iridium spark plugs
I bought some NGK Iridium spark plugs today and was wondering if anyone has ever used them before?
DSBirdman89 is offline
post #2 of 15 (permalink) Old 03-19-2005, 03:47 AM
I run NGK coppers Great Plug !!!
Iridium will last years longer
LST MN-12 is offline
post #3 of 15 (permalink) Old 03-19-2005, 06:31 AM
joshbea6's Avatar
Definitely keep us posted as to how well they do for you.
joshbea6 is offline
post #4 of 15 (permalink) Old 03-19-2005, 07:47 AM
David Neibert's Avatar
I've been using them for a couple years. They also hold up better than platinum tipped plugs when using nitrous.
David
David Neibert is offline
post #5 of 15 (permalink) Old 03-23-2005, 02:44 PM Thread Starter
alright, ill keep you guys posted, they came in today, installing tomorrow
post #6 of 15 (permalink) Old 03-23-2005, 06:11 PM
I am running plain old NGKs in all my vehicles. The higher mileage plugs are no good for me because I find that they are getting carboned up in time and need to be removed to be cleaned anyway. The Corvette people claim that the iridium plugs are no good because the tips fall of prematurely. I am going to stick with the $1.50 NGKS and change them every two years (smog time).
Bluebird
97Bluebird is offline
post #7 of 15 (permalink) Old 03-23-2005, 06:59 PM
Let us know how they work. Ive always used Champion Coppers. Only last about a year but the car runs great with them.
Blue LS is offline
post #8 of 15 (permalink) Old 03-25-2005, 11:39 AM Thread Starter
put them in yesterday,the car actually runs smoother than with the Bosch Platinum +4 plugs. Iridium all the way!!
post #9 of 15 (permalink) Old 03-25-2005, 12:04 PM
bowez's Avatar
Reason
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #10 of 15 (permalink) Old 03-25-2005, 05:08 PM
I did the iridium plug thing. No doubt a big difference when you fist put them in. But there are four things that make the wind blow after you've tried every plug under the sun. 1) Any new plug will out perform any old plug with more than 10,000 miles on it . 2) Plats can claim less resistance and increased plug life. 3) Iridiums claim increased horsepower. 3) The fact of the matter is no matter what plug you use, after about 10,000 miles any new plug on the market will out perform the old one in your car. 4) I have found that the correct plug gap on a new plug is more important than the plug itself. Hot VS. Cold is another issue. Ed.
Hollywood Ed is offline
post #11 of 15 (permalink) Old 04-11-2005, 12:12 AM
Can a spark plug really improve horsepower?
accessdenied is offline
post #12 of 15 (permalink) Old 04-11-2005, 01:35 PM
bowez's Avatar
Well there is a maxium effect, but if is a better condutor then yes.
Gold and Silver would be the best for electrical conductance but they both are "soft" and do not deal with heat well, Copper is a better conductor than Platinium but Plat is better at slowing carbon build up.
I anit got a clue as to the benefits of Iridium.
93 SC Tbird
93 5.0 Tbird
bowez is offline
post #13 of 15 (permalink) Old 04-11-2005, 01:52 PM
winkeytoofly's Avatar
Watch out wit the +4, they can be to hot of spark, when i was a memeber on a Intrepid site i remeber ppl were having problems wit the Boschs. I believe it was damaging the top of the pistons. Really u dont need that hot of a spark coppers do just fine.
winkeytoofly is offline
post #14 of 15 (permalink) Old 04-11-2005, 04:54 PM
I would bet my paycheck that any spark plug that claims platinium or iridium is just coated with the stuff and is really copper inside when you scratch it . Without going into rocket science, the problem with copper is not the resistance of a new plug, but the oxidation it creates (over time ) from being exposed to air. The oxided copper will create more resistance in the wire compared to platinum over time. That's why we have oxygen free copper speaker cables and silver and platinum coated spark plugs. They can claim that the expensive treatments will create something that will stand the test of time. And that is true, but, we experiment by nature. The time you put into making the gap of each plug consistant with the others, is where the time is spent, not in the cost of the spark plug. Don't get caught up in the testimony that the new is better, that's the stuff you see on TV when you should be sleeping. Be more aware of where you are right now. 1 dollar of copper can be replaced 10 times at the cost of platinium. And replacing and experimenting is what we do best. That's where the fun is. ED
post #15 of 15 (permalink) Old 04-11-2005, 06:35 PM
bowez's Avatar
Well on average platiniums cost only 2x as much as copper an considering the time to change I'll spend the extra $6-8 and save myslef a min of 30mins.
93 SC Tbird
93 5.0 Tbird
bowez is offline
