Which Brand Injectors? - TCCoA Forums
post #1 of 1 (permalink) Old 03-28-2005, 01:42 PM Thread Starter
PCD
Confirmed V6 Nut
I have a choice to make, but have no information to do it with. In building up my engine, I'm going to need bigger injectors. 24LB injectors is the common advice, but I find that there are 2 brands Ford uses in the V6--Bosch and Fprd/Denso. I've looked over the verbiage at Five0 Motorsports. It seems that there is a Bosch Design III that is supposed to be better than the Bosch Design II injectors. What is the knowledge and experience out there for 24LB injectors?
PCD is offline
