motor swap to a 00 3.8 - TCCoA Forums
post #1 of 10 (permalink) Old 03-28-2005, 11:19 PM Thread Starter
hey i got a 2000 3.8 motor and i heard they have 190 hp well if i do this motor swap and add my underdrive pullys with my dual exhuast with headers that will give me up in the 200 hp but will this motor swap be hard i mean and worth it
lowthunder is offline
post #2 of 10 (permalink) Old 03-29-2005, 07:58 AM
PCD
Confirmed V6 Nut
You will have to do some fitting. Racecougar did it and he got his letter in Car Craft Magazine with a pic of the car doing a burnout.
PCD is offline
post #3 of 10 (permalink) Old 03-29-2005, 08:21 AM
Litning's Avatar
Your current Underdrive pulleys will NOT work. They started using integrated pulleys and harmonic balancers after 1999. You would need to buy a new underdrive pully (about $150-170).
Yes the swap will be VERY hard for your car:
1. you either have to convert to a DIS system
1a. or you have to try to figure out a way to keep your distributor
2. you have to custom fit a fuel rail to the engine to work with your fuel system
3. you will need to get a chip/flash for your computer as the larger fuel injectors will not work with your current computer
I am sure there are other reasons, but I have not come across them yet.
Litning is offline
post #4 of 10 (permalink) Old 03-29-2005, 11:25 AM Thread Starter
i got the whole motor with pully on it and all i just don't got the trany or the computer for it but other then that i got everything all the way to the pullys and mainifold
post #5 of 10 (permalink) Old 03-29-2005, 03:01 PM
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
your tranny will work, i believe. theres alot of work involved in making this swap work right. its not a swap in and plug everything up and go.
2014 GT
1990 300ZX TT
big mike is offline
post #6 of 10 (permalink) Old 03-29-2005, 03:21 PM
Litning's Avatar
if it was easy, everyone would do it
Litning is offline
post #7 of 10 (permalink) Old 03-29-2005, 03:44 PM
bowez's Avatar
I'd suggest grabing a DIS EEC or at least find out what the differences are. A couple guys at V6power can/do make the fuel rails.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #8 of 10 (permalink) Old 03-29-2005, 05:48 PM
He can run the distributor if he eliminates the EGR. Or he could go with an F-150 upper like PJ did. Just throwing my 2 cents in!
post #9 of 10 (permalink) Old 03-30-2005, 10:11 AM Thread Starter
kool and hey every cents helps man. i know its not goin to be a plug and go swap but i am doin it i just need to see what all i need for this swap so keep it up and if you got anything eles just add it in thanks
post #10 of 10 (permalink) Old 03-30-2005, 06:06 PM
Brings new meaning to the phrase "Plug And Play". lol
jimmy_04 is offline
