Question not For Related, but 3.8 - TCCoA Forums
post #1 of 5 (permalink) Old 04-06-2005, 10:58 PM Thread Starter
In my 93 Bonneville, I am having some wierd issues going on.
Only with around a 1/4 tank of fuel, Braking hard.
The engine will stall out, while braking hard, RPM's drop and engine dies, starts right back up though.
I would guess fuel system some where, but I have no idea where to start.
If I have a half of tank or more, and I brake hard, this does not happen.
Very wierd problem.
Thanks Alot
Dave
DMcBrideBoston is offline
post #2 of 5 (permalink) Old 04-06-2005, 11:26 PM
My guess is the fuel pump???? The pick-up for the fuel is screwed????
Trevorbird is offline
post #3 of 5 (permalink) Old 04-07-2005, 11:03 AM
girdnerg's Avatar
Could be the sending unit and/or gauge. I replaced the pump on my Dodge mini van (pump and sending unit all in one box). Now the thing runs out of gas at 1/2 tank .
When it dies and you then fill up, how much does it take? My point is that the gauge/sending unit may be giving you a false reading and you are actually out of gas at 1/4 tank.
Easy to check as you have to fill her up anyway.
Rob
girdnerg is offline
post #4 of 5 (permalink) Old 04-07-2005, 10:02 PM Thread Starter
I had thought of this but, as long as I am not braking, it doesn't die. It has to have something to do with the shifting of the fuel to the front when I am breaking and what not.
I will hate to have to fix something already on this car, or at the very least fill up all the time to keep gas in the tank
Thanks guys...
Dave
post #5 of 5 (permalink) Old 04-10-2005, 10:06 PM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
www.ClubGP.com
Thomas is offline
