95 3.8 problems - TCCoA Forums
post #1 of 29 (permalink) Old 04-07-2005, 04:58 PM Thread Starter
95 3.8- Water in intake?
Has anyone ever had problems with their 95 3.8? I went through 2 motors due to rod knock so far, but I think i know what the problem is. I know that those motors are known for rod knocks, but i think water is getting into my engine via air filter. I have a K&N ram air setup, and my motor has only gone after it has rained. So when I get the car back, I'm taking off the filter and going back stock for the time being. Can someone help me with this issue? Is it the water giving me this knock?
Joshua is offline
post #2 of 29 (permalink) Old 04-12-2005, 12:25 AM
Iowa Chapter Director
Uber Luber
Thomas's Avatar
how does the car have "ram air"? Where is the filter located?
Usually the rod knock is caused by the headgaskets blowing and coolant getting into the oil pan, resting on top (because it has less mass than oil) and washing out the journals, so they run without oil and wear out.
-Thomas
Thomas is offline
post #3 of 29 (permalink) Old 04-12-2005, 12:38 AM
Did you tear down the 2 engines that went bad? If you're sucking water into the engine you run the risk of hydrolocking a cylinder. Were these new engines, rebuilt, used, etc?
-Rod
post #4 of 29 (permalink) Old 04-12-2005, 06:19 AM
jay
jay's Avatar
Sinde Josh isnt around I will answer some Q's since im good friends with him and help him with his bird all the time.
Okay we mounted the K&N right in the front right corner of bumper.Just in front of the bumper slot/hole on the 95 bumper. We think it could be bc of that bc my buddy had a focas with cold air and hit a pot hole with no airbypass valve and blew the motor.
Also he took it on a 3 hour trip and it was pouring and he was doing 120KMP+ so i bet the filter coulda suced some water in.
To answer racecougar the first time he brought it to the shop and they put a rebuilt in there with a 20 000KM warrenty or so and after 19 000 it acted up so I told him to bring it in and yep another rod not not as bad as b4 but it still was. So another rebuilt is going in covered thru warrenty.
Hope this answered all
Jay
1990 Ford Thunderbird 3.8L V6 N/A
SOLD
1989 Ford Thundebird 3.8L V6 N/A (PARTS CAR) GONE
My Bird
MY BIRD ON SOUND DOMAIN
TCCOA PAGE
jay is offline
post #5 of 29 (permalink) Old 04-12-2005, 07:48 AM
I found that where you have your Filter ( Behind the foglight hole) Thats where I had mine It felt like I was loosing HP. It might be all in my head, but the extra bends and length slowed the air coming in. This may sound dumb but just my opinion. I think If you just 90 the Pipe through the hole from the factory silencer Is the best. My other way looked cooler you can see it resting on the Black valence from in front of the car. I've driven through lots of rain like that with no bypass and I've never had any problems.
Trevorbird is offline
post #6 of 29 (permalink) Old 04-12-2005, 08:51 AM
Drnaline's Avatar
They do make a valve for such cases. It's a bypass that opens when and if your hose is submerged. I'll look for a link.
Democracy is 2 wolves and a lamb voting on dinner. Liberty is a well armed lamb contesting the vote.
Drnaline is offline
post #7 of 29 (permalink) Old 04-12-2005, 02:58 PM
jay
jay's Avatar
I ya i know about the air bypass valve but to buy one or just relocate filter he will prob just relocate cheaper lol.
SOLD
My Bird
TCCOA PAGE
jay is offline
post #8 of 29 (permalink) Old 04-12-2005, 04:24 PM Thread Starter
Thanks for answering those questions for me Jay. So, does anyone think it's water getting in the engine through the filteR? I talked to a guy at the Ford dealership in town about the 3.8, he said the only ones he's worked on where there was a rod knock was when there was a water pump problem, and coolant was getting in that way, but is that a gasket problem? Cuz on a new motor, it's all new gaskets, and that's what leads be to think it's the filter.
Joshua is offline
post #9 of 29 (permalink) Old 04-12-2005, 09:23 PM
Drnaline's Avatar
It would be hard without you notiving some kind of problem. Did you notive any steam when it happened?
Drnaline is offline
post #10 of 29 (permalink) Old 04-12-2005, 11:47 PM Thread Starter
no, not from what i've seem. there's no sign of anything really, other than the knock. this problem's got me stumped.
Joshua is offline
post #11 of 29 (permalink) Old 04-13-2005, 12:03 AM
Uber Luber
Thomas's Avatar
have you checked your intake tube after driving on a rainy day to see if it's wet inside? Have you done a cooling system pressure check?
-Thomas
Thomas is offline
post #12 of 29 (permalink) Old 04-13-2005, 08:37 AM
Drnaline's Avatar
Maybe the intake is leaking coolant into the engine.
The flange seal onthe head side of the intke are OK. I have seen electrolosis eat the aluminim and acuse leaks internal.
Drnaline is offline
post #13 of 29 (permalink) Old 04-13-2005, 06:14 PM Thread Starter
i checked it once, the second engine, but it was barely raining. anyways, i went to school and pulled in a parking spot, and i had a drop in oil pressure. i didn't hear any noises tho, but i hardly ever give it more than half throttle. anyways, i checked the intake and it was dry from what i felt, but it was only slightly raining. i checked my oil after that, and i was almost a quart low. the engine was leaking a little, at the back near the tranny, and there is oil spatter on the whole bottom side of the motor. the shop said there's no problem with lack of lubrication. the leaking doesn't make sense to me tho.. i mean, bad gaskets on a new engine??
Joshua is offline
post #14 of 29 (permalink) Old 04-13-2005, 10:22 PM
Drnaline's Avatar
What does your coolant level stay at? Did that go down too?
Drnaline is offline
post #15 of 29 (permalink) Old 04-13-2005, 10:30 PM Thread Starter
coolant level has been good, every time i check it's usually between the hot and cold marks. my engine never seems to get hot tho... the needle on the temp gauge stays between the blue and the firt line. never goes into normal operating zone...
Joshua is offline
post #16 of 29 (permalink) Old 04-13-2005, 11:10 PM
Drnaline's Avatar
Were the two engines the same block or were they different? and also was it the same rod the made the knock?
Drnaline is offline
post #17 of 29 (permalink) Old 04-13-2005, 11:14 PM Thread Starter
no, the second motor was a different remanufactured block from what i understand, and i don't think they were the same rods knocking. i know they were on opposite sides of the motor, i'm going to take a guess and say the first one was cylinder 4, and the second was 1 or 3.
Joshua is offline
post #18 of 29 (permalink) Old 04-13-2005, 11:44 PM
Drnaline's Avatar
I would kinda have to believe that it wasn't to do with water. I mean from your intake setup. If they thought that was one of the probables I don't think they would of waranteed it.
Drnaline is offline
post #19 of 29 (permalink) Old 04-14-2005, 08:11 AM Thread Starter
yeah, i was thinking that, but it is a small garage and i'm friends with the owner. maybe it's just a case of bad luck, who knows. i'm still going to relocate the filter, i don't know what else to do really
Joshua is offline
post #20 of 29 (permalink) Old 04-14-2005, 08:35 AM
Drnaline's Avatar
Did you get a chance to see what the oil looked like? I'd also make sure your intake is properly torqued down.
Drnaline is offline
post #21 of 29 (permalink) Old 04-14-2005, 05:24 PM Thread Starter
no, but from what they tell me at the garage, the oil's good. one thing that was never done on the last motor was the retorquing of the heads... maybe that's the cause?
Joshua is offline
post #22 of 29 (permalink) Old 04-14-2005, 10:50 PM
Uber Luber
Thomas's Avatar
they are new bolts though right? I know few people who actually go back in and retorque them, but if it were my car, I would.
-Thomas
Thomas is offline
post #23 of 29 (permalink) Old 04-14-2005, 10:55 PM Thread Starter
good question. i sure hope they are new bolts. i know last time my buddy at the garage said i wouldn't hafta retorque them, but i wanted to get them done anyways, but then he said it's too much work, wait til they need to be torqued
Joshua is offline
post #24 of 29 (permalink) Old 04-15-2005, 09:16 AM
Drnaline's Avatar
I don't think that year are torque to yield but could be wrong. If they are that is definitly a problem.
Drnaline is offline
post #25 of 29 (permalink) Old 04-15-2005, 11:53 AM
jay
jay's Avatar
The head bolts should be new the block came with the heads on already when we looked at it josh! If i remember right........I still dont know y u can drive urs normal and i can beat the piss outta mine and it runs good??LOL
Jay
SOLD
My Bird
TCCOA PAGE
jay is offline
post #26 of 29 (permalink) Old 04-15-2005, 12:13 PM
Uber Luber
Thomas's Avatar
ALL Ford v6's have torque-to-yield headbolts, in fact, almost all Ford engine have them.
-Thomas
Thomas is offline
post #27 of 29 (permalink) Old 04-15-2005, 04:19 PM Thread Starter
tell you the truth jay, i don't remeber. i didn't take that good of a look at the new block, but if you say they're new bolts, i believe you. lol. anyways, it was part of the warrany, when i take it in at 800 km for an oil change, they're supposed to retorque the heads. i'll hafta make them retorque them this time
Joshua is offline
post #28 of 29 (permalink) Old 04-16-2005, 11:03 AM
Drnaline's Avatar
-Thomas
The early rattle trap 2.8 V6's, with the iron heads didn't have torque to yield.
Drnaline is offline
post #29 of 29 (permalink) Old 04-16-2005, 06:27 PM
Uber Luber
Thomas's Avatar
by the ford v6, I was referring to the one in the same family as the 3.8, ie: 3.8, 3.9, and 4.2.
Thomas is offline
