Dead fuel gauge? - TCCoA Forums
post #1 of 7 (permalink) Old 04-10-2005, 01:34 PM Thread Starter
Dead fuel gauge?
Okay, I thought I could live with it, but when she stared to choke on the expressway I got spooked...
My gas gauge is permanently stuck on E. I've been told that it's either a ground wire or that the sender inside is rusted tight, but that's sight unseen. I would think (even though I try not to) that if the sender were rusted, the needle would be stuck somewhere in the range, and not at the E? Anynoe else have any insight on this sort of thing?
CloudRider is offline
post #2 of 7 (permalink) Old 04-10-2005, 02:27 PM
winkeytoofly's Avatar
My Bird has a a problem liek that too, it tends to lean over to the right after its started so it makes me think i have more gas then i really do.
winkeytoofly is offline
post #3 of 7 (permalink) Old 04-11-2005, 02:19 AM
my temp gauge does that, it want move at all it stay all the way over on the cool side
lowthunder is offline
post #4 of 7 (permalink) Old 04-11-2005, 12:05 PM
debtman3535's Avatar
lowthunder...
check the connector - it's right by the vent plug. I had the same problem until i sqeezed the connector a little to tighten the connection and she was good as now.
I take full responsibility for this post. Anything I've written here is an opinion.
1994 Cougar XR7 V6 - Black. New Paint, Alpine HU, Infinity Perfects, Phoenix Gold Amps, Audiobahan Sub, PG 232 EQ
debtman3535 is offline
post #5 of 7 (permalink) Old 04-14-2005, 07:16 PM Thread Starter
So no one's got anything on the gas gauge?
post #6 of 7 (permalink) Old 04-20-2005, 01:10 PM
Mine doesn't work either, after checking all the wireing I came to the conclusion that it's the sender in the tank, which costs like $250cdn, so i just use my trip counter to know when to fill up, that or when the car starts to fart,lol.
Macho Mechanic is offline
post #7 of 7 (permalink) Old 04-20-2005, 01:46 PM
mine tends to sway back and forth randomly.. it changes by about a 1/4 at the most, but it always varies alittle. ive kinda just grown to ignore it and just guess its actually somewhere between the two extremes
93tbirdbumpin is offline
