engine running warmer w/ flowmaster? - TCCoA Forums
post #1 of 6 (permalink) Old 10-20-2002, 10:57 AM Thread Starter
I heard somewhere that when you put a flowmaster on, the engine will run warmer. I forgot if he said just for a little while, or forever....
But...I put a flowmaster 40 series muffler on my car Friday, and on the way home I noticed that my temp gauge was higher than normal and the oil pressure was a tad higher also. The weather was low 50's and rainy.. Now, last night i drove about 30 miles in the same weather conditions and it didnt heat up at all. Was I just seeing things, or was the comment about the flowmaster really true?
weswing04 is offline
post #2 of 6 (permalink) Old 10-20-2002, 07:18 PM
I dont see how that can have any effect, if anything a tiny minut lower temp of like a degree or something from more flow and less time for the exhaust to heat but just a muffler wouldn't make that difference
Jimbo is offline
post #3 of 6 (permalink) Old 10-20-2002, 08:28 PM
CamellionCat's Avatar
Send a message via AIM to CamellionCat
would glasspacks and removed cats?????
make the car run warmer b/c mines is, i gutted the cats and i have dual glaspacks and my car will run to the R in NORM. I think it might be the gutted cats.... but hey more flow right????
Marvin M.
95- Cougar- SOLD (in loving memory)
Mods-17x9 cobra r's,H&R springs,KYB shocks & struts,removed air silencer,9"K&N cone,gutted cats,dual glasspack setup,cooling fan switch, B&M 24,000 tranny cooler.
Back in the game!!!
97 Lincoln Mark VIII LSC-opal opalescent with black interior, upgraded with a 98 tranny, 18x9 black saleen speedstars, LMS dual tip mufflers, 5% tints all around.
CamellionCat is offline
post #4 of 6 (permalink) Old 06-06-2003, 11:47 PM
Running gutted cats and glasspacks, you are looking forward too some burnt valves....
Cruznlife1 is offline
post #5 of 6 (permalink) Old 06-07-2003, 03:27 AM
What causes the valves to burn? Is it the gutted cats or the glass packs? I have gutted cats, and just replaced the large cat with a high flow cat and dual flowmasters......am I ok or do I run the risk of the burnt valves also??
94ONAIR is offline
post #6 of 6 (permalink) Old 06-09-2003, 12:53 PM
96fordtbird's Avatar
Send a message via AIM to 96fordtbird Send a message via Yahoo to 96fordtbird
I had flows put on my car and have been noticing it getting warmer in temp. I only started to notice it on my trip back from Missouri. My temp gauge has been peeking over the half-way point a couple of times in the last week. I have a new thermostat to put in when i have a chance. I dont know if this will help at all.
Anyways , mine has been getting warmer also and with the temp's in the morning you wouldn't think it would get that warm. 50-65 degrees in the morning in Oklahoma
96fordtbird is offline
