Evaporative Emission Control System Control Valve ~ Where is it??? - TCCoA Forums
post #1 of 2 (permalink) Old 10-20-2002, 09:23 PM Thread Starter
Question Evaporative Emission Control System Control Valve ~ Where is it???
I have a check engine light illuminated and had our friends at Autozone check it for me. The code came back as P1443 which is a Evaporitive Emmision Control System Control Valve. My Haynes doesn't list it.
Can anyone tell me what it is? where is it? How do I replace/repair it?
Thank you in advance.
LastBoyScout is offline
post #2 of 2 (permalink) Old 10-20-2002, 09:56 PM
If you have a Haynes, look up Fuel Evaporative emissions control system, Pg 6-11. What the codes likely refer to is the canister purge solenoid valve.
Try not to take code readings verbetim.
soop is offline
