Article comments here please... - TCCoA Forums
post #1 of 28 (permalink) Old 10-26-2002, 12:20 PM Thread Starter
PJ-4.2L's Avatar
Send a message via AIM to PJ-4.2L
Sir, William. Could you lock the 4.2 swap post I made? Maybe making it sticky or archiving it might be nice...
Thanks!
PJ
PJ- 4.2L -
" 'DIY' was not meant for women."
PJ-4.2L is offline
post #2 of 28 (permalink) Old 10-26-2002, 01:08 PM
so with a 96 u can use the mustang intake since it has distributerless? sp
If so how do you delete the dist on the engine itself?
billabong132 is offline
post #3 of 28 (permalink) Old 10-26-2002, 01:26 PM Thread Starter
PJ-4.2L's Avatar
The 4.2 uses DIS in stock form. It has a crank angle sensor instead of a distributor. I took the sensor out and put my distributor in.
PJ
PJ- 4.2L -
PJ-4.2L is offline
post #4 of 28 (permalink) Old 10-26-2002, 01:36 PM
cool deal, I forgot to say thanks for the article and I hope your move went ok.
post #5 of 28 (permalink) Old 10-26-2002, 06:47 PM
Welcome Back PJ! wonderful artical there!
rancherlee is offline
post #6 of 28 (permalink) Old 10-26-2002, 07:04 PM Thread Starter
PJ-4.2L's Avatar
Thanks, guys. I'm all settled in Oxnard now. I just need to find a job as soon as possible. Besides that, I have my work cut-out for me. I need to finish some body-work on my RX-7 and then some body work on my girlfriend's '92 GT. After that, I will be re-torquing the timing cover on the T-Bird. It seems like the work never ends...
PJ
PJ- 4.2L -
PJ-4.2L is offline
post #7 of 28 (permalink) Old 10-26-2002, 07:14 PM
Very nice job. There is hope for 3.8 owners. That is the project for the future on mine. Looking forward to it.
Thanks for the experience and detail.
soop is offline
post #8 of 28 (permalink) Old 10-27-2002, 07:59 PM
Thumbs up Article comments here please...
PJ, Thanks!
post #9 of 28 (permalink) Old 10-28-2002, 01:41 PM
cmd146's Avatar
Terrific Article PJ! You presented us with all the information I needed to know, and it reads like a Haynes repair manual.
Sir William - If PJ agrees, I think this article should be posted under the engine tech articles section. There isn't anything there for us V6 guys now.
1995 LX Electric Red 3.8, K&N intake, Reinhart Chip.
1965 Mustang HP289
I'm selling many 1960's Mustang and Ford parts. Have a rebuildable 289, an FMX trans, complete 67 coupe body with glass - send me PM.
cmd146 is offline
post #10 of 28 (permalink) Old 10-28-2002, 01:51 PM Thread Starter
PJ-4.2L's Avatar
I have a few tweaks to take care of... typos, numerical figures (thanks, G.E.), etc. I have the article in .doc format and html/vB script I used on this board. If anyone sees anything missing, or want something better explained, please let me know so I can improve it.
PJ
PJ- 4.2L -
PJ-4.2L is offline
post #11 of 28 (permalink) Old 10-28-2002, 01:54 PM
PJ,
Do you want to go into any more depth on why you chose the distributor over the DIS? Simply for the manual timimg adjust at the track or are there other (using stock EEC) issues?
doodaa is offline
post #12 of 28 (permalink) Old 10-28-2002, 02:14 PM Thread Starter
PJ-4.2L's Avatar
To use DIS I would need an EEC from a car with DIS-- like the truck's or an SC, or laet model Mustang...
My reasons for not using DIS:
a: I was not willing to spend the extra cash/time replacing EECs, harnesses, etc. Just keeping it simple.
b: I wanted there to be a reason for owning the Cobra R hood (keeping the truck intake was not a big deal
c: I wanted to maintain ability to adjust timing in case of problems, or if I was planning on running better/worse fuel in hotter temps.
Besides, I had read something on v6power.net saying that the truck intake was better for boosted applications, and it made the choice easy.
Keep on posting Qs here, I will add them to the article.
PJ
PJ- 4.2L -
PJ-4.2L is offline
post #13 of 28 (permalink) Old 10-28-2002, 02:34 PM
PJ
hhmmm, a little of both and then some... ok, a few more clarifications then.
a. If I just happen to have a '91 auto SC parts car in the driveway I could probably use the EEC from that? Then it's only the time to change the harnesses? Not simple but not impossible either...
b. Granted, that's a good reason and your car looks way better than mine. But that hood cost more than my parts car (less transport) and I'm a cheapskate who's too old to be getting girls with his car, cash in the wallet talks louder these days.
c. Why not an EEC tuner for timing adjustments? Too many $$$ or not one avail for application?
doodaa is offline
post #14 of 28 (permalink) Old 10-28-2002, 04:10 PM
PJ [/B]
Could you have used the 99+ Mustang throttle cable instead of the 4.2 truck cable?
post #15 of 28 (permalink) Old 10-28-2002, 04:31 PM Thread Starter
PJ-4.2L's Avatar
Doodaa: The SC EEC should work as long as you get a chip programmed for the new setup. If you use that and DIS, you will be able to run the Mustang intake and stock hood. I won't be able to help you, however, with setting up the MSD RPM switch since I hooked it up to my ignition coil. I think the DIS has multiple coils... (am I right?) I am sure there is still a way to hook the switch up anyways.
As far as the EEC tuner, it's a possibility, but the distributor is a little quicker for immediate changes (I think). Money was an issue, but sooner or later I will have an MSD ignition setup which will allow me to adjust timing on the fly from within the car. I haven't had any pinging problems yet, and I don't know if I am improving power with timing tweaks until I get it on a dyno- at which point it will make more sense to let the pros dyno tune it.
Rodeo Joe: I think that the crucial matter is that you get a throttle cable that matches your throttle linkage and bracket-- so if you choose the truck t-body and intake, get the truck cable. If you have a Mustang intake with its corresponding TB, use the Mustang cable. Since I didn't mess with the Mustang stuff, I really can't say for sure.
PJ- 4.2L -
PJ-4.2L is offline
post #16 of 28 (permalink) Old 10-28-2002, 04:38 PM
PJ,
I was thinking on those same lines also. I'm planning on a Mustang split port swap head sometime next year, and figured I'd need to go with the Mustang cable. Thanks for your input.
post #17 of 28 (permalink) Old 10-28-2002, 05:15 PM
Well, I'm no expert on DIS, just seems like it might be a better way to go for me ... I guess I'll give it a shot and see what happens. Worse that can happen is it won't run until I figure it out
Can the chip guys maybe add IMRC function to that '91 EEC?
doodaa is offline
post #18 of 28 (permalink) Old 10-28-2002, 05:51 PM Thread Starter
PJ-4.2L's Avatar
Even if you could program the EEC to trigger it, you would need to have some custom wire harnesses... The RPM switch isn't really that hard or costly (50 bucks for unit and a few more for the pills).
PJ
PJ- 4.2L -
PJ-4.2L is offline
post #19 of 28 (permalink) Old 10-29-2002, 12:00 AM
One littel nit picky thing. You said in your artical that the 96+ N/A V6 have DIS. Well my 96 dosen't have DIS, I got a big distibuter instead.
Other than that good job, I just might make that swap if I ever get the cash saved up.
You are now my new personal hero.
Jemplayer is offline
post #20 of 28 (permalink) Old 10-29-2002, 06:56 AM
Hmm, you're the first I've ever heard had one. I thought Ford changed all the 3.8 to DIS after 95.
post #21 of 28 (permalink) Old 10-29-2002, 10:18 AM Thread Starter
PJ-4.2L's Avatar
Thanks for the notice. I will make a note of it. Is there any possibility that someone swapped a different engine into your '96?
PJ
PJ- 4.2L -
PJ-4.2L is offline
post #22 of 28 (permalink) Old 10-29-2002, 01:26 PM
No the car was bought new by my grandmother in '96, don't remember the month, but the mfg date says 3/96. Could it be one of those half year change kind of things?
post #23 of 28 (permalink) Old 10-29-2002, 11:52 PM
EVERY 96-97 MN-12 V6 should have DIS....... got any pictures? 94-95 can be either DIS or Distibutor.......... Possible that your 96' might be a canadian car (not requiring OBD-II) which might be the ONLY explination for your car having a distributor.
post #24 of 28 (permalink) Old 10-30-2002, 07:53 AM
If you can tell me how a canadian car was bought new off a lot in south mississippi I would love to hear it. Now I'm really confused?
I know it's got a distibuter becuase there are no coil packs anywere, changed the sparkplugs to many times.
I'm begging to think my car is just a freak of nature.
I really wich it had DIS would make the swap much eaiser.
post #25 of 28 (permalink) Old 10-30-2002, 08:14 AM
Your would be the FIRST 96' I've EVER seen with a distibutor, the COILPACK on the DIS cars is right where the distributor used to be on the older ones......
94-95 California emissions cars were DIS and
96-97 ALL 3.8L's should be according to a few different sources....
Maybe we need a POLL on this
My car was born 8/96
post #26 of 28 (permalink) Old 11-10-2002, 07:07 PM
Wait I got a question.
How about usolder t-bird people is this still gonna work the same or is this swap gonna cause some other problems in the '91 and older.
Willow9238 is offline
post #27 of 28 (permalink) Old 11-10-2002, 07:12 PM Thread Starter
PJ-4.2L's Avatar
I don't forsee any problems as long as the tranny bolts-up. I don't know if any electronic changed would be needed.
PJ
PJ- 4.2L -
PJ-4.2L is offline
post #28 of 28 (permalink) Old 11-10-2002, 09:52 PM
Is the bell houseing for the 4r70w is the same as the AOD? And if so is the bolt patten the same?
Will
